Author Topic: FUEL CELL SENDING UNIT TO AUTOMETER GAUGE  (Read 6533 times)
Offline KILLERC10
« on: November 10, 2010, 09:14:10 pm »
WELL I JUST GOT A NEW FUEL CELL FROM JEGS THAT CAME WITH A 90 OHM SENDING UNIT, I WANTED TO KNOW WHAT WIRES GO WHERE TO A AUTOMETER FUEL LEVEL GAUGE. ANYONE HAVE ANY PICS OR LINKS ON HOW TO WIRE UP THAT STUFF? IVE NEVER DONE ONE BEFORE SO ANY HELP WOULD BE GREAT. THANKS
Re: FUEL CELL SENDING UNIT TO AUTOMETER GAUGE
« Reply #1 on: November 11, 2010, 05:33:17 pm »
do you have your autometer gauge instructions?  Should be listed there, did you get a GM compatible gauge?
Offline HAULIN IT
« Reply #2 on: November 13, 2010, 03:55:16 pm »
Hooking up the sending unit to the gauge is as simple as one wire, however as Chris mentioned...you need a "GM" compatible gauge to go with your 0-90 ohm GM type sending unit. Some gauges are made having high ohm readings as empty, usually around 75 ohms (most Ford & Dodge that I know of) & go to 0 at full, while the GM's start at 0 & go to about 90 at full. You can probably check Autometer's website to find out which gauge you have if you have a part number. Hope this helps. Lorne
Offline KILLERC10
« Reply #3 on: November 13, 2010, 07:40:48 pm »
HEY THANKS EVERYTHING WORKED OUT
