Author Topic: 1980 C20 door hinge replacement  (Read 3781 times)
Offline tigwelder
« on: November 10, 2010, 09:19:48 pm »
i am going to replace the right and left upper door hinges. is there an easier way to do this now compared to 10 years ago when it was almost impossible to do it without removing
 the fenders.
Re: 1980 C20 door hinge replacement
« Reply #1 on: November 11, 2010, 05:32:00 pm »
Nothing easy about changing the hinges.
Offline drtch1
« Reply #2 on: November 30, 2010, 08:50:19 pm »
If your wanting to replace just the hinge pins and the brass bushings you need just to remove the door (make sure to mark the door bolts using a sharpie). If the whole hinges you have to take off the door and fender.
