Electrical
relay kit
Topic: relay kit (Read 14394 times)
GUITAR1989
relay kit
November 11, 2010, 12:24:47 am »
Hey guys i got my relay kit in and put in some Hella H4 headlights
they look great. Im just wondering if i need to throw some fuses in the harness. I read a link that captkaos linked in someone elses poste about headlight upgrades but the write up was on a home made relay kit so im not sure if the kit is different and doesnt need to have fuses. If it does what size wire and fuses should i use?
Last Edit: November 11, 2010, 05:20:29 pm by Captkaos
Armor
Re: relay kit
November 11, 2010, 07:05:11 am »
when i did mine i ran the power right from the battery, and put in fuses, i figured if the lightes ever grounded its better to fuse it then to let it burn. if i recall i used a 30A fuse for each system, one for each hi beam and low, and i used 10 gauge wire. One of the best choices ive made to have amazing headlights on old Blue.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
Re: relay kit
November 11, 2010, 07:50:40 am »
Fuse it. If something goes wrong the wires will melt and possibly catch fire if there's no fuse.
Grim 82
Re: relay kit
November 11, 2010, 08:42:26 am »
+1 for fuses. I picked up two inline spade type fuseholders from the local parts store and IIRC I put a 15A in each. I used ring terminals from the junction block on the firewall then through the fuseholders, into the harness and then mounted the relays on the drivers side inner fender. It's a very worthwhile upgrade.
GUITAR1989
Re: relay kit
November 11, 2010, 09:41:28 am »
Im not verry knowledgeable about wiring
im not quite sure what wire the fuse goes in. should i put the fusees in the wires that draw power from the battery?
Grim 82
Re: relay kit
November 11, 2010, 10:27:14 am »
You'll have 2 wires that go to the power source. You want the fuse as close to the power source as possible. In my case, I used the junction block on the firewall as a source instead of the actual battery, so I attached the fuseholders right to the source and then connected it to the main power wires.
GUITAR1989
Re: relay kit
November 11, 2010, 11:12:28 am »
How do I determine what size fuses to put in there?
Grim 82
Re: relay kit
November 11, 2010, 11:35:11 am »
http://www.tacomaterritory.com/forum/showthread.php?p=2041129
beastie_3
Josh
Re: relay kit
November 11, 2010, 11:54:01 am »
That is odd, my kit from the same company came with a fuse.
Semper Fi
Re: relay kit
November 11, 2010, 05:27:38 pm »
I sell this relay kit, just not made it into the catalog yet.
http://shop.americanautowire.com/headlightenhancerrelaykit-1.aspx
GUITAR1989
Re: relay kit
November 11, 2010, 05:48:43 pm »
yeah most of the relay kits ive seen since i bought this one look alot more solid xD but ive gotta work with what i got. im still not sure what size fuses i should use though. beastie what size fuses did u end up using?
beastie_3
Josh
Re: relay kit
November 11, 2010, 05:54:28 pm »
OK I was wrong. The leads just had ring terminals so I cut them off and wired in a fuse. It has a 25 amp fuse now. Dunno if that is too big or not.
Semper Fi
Electrical
relay kit
