Author Topic: Anyone running Big Block?  (Read 7028 times)
Offline TxFiddler
« on: November 11, 2010, 04:22:26 pm »
I have a few questions for anyone that is running a big block in their truck.  I am putting a 396/402 in my 1980 C10 LWB 2wd.
If you can, please answer the following:
Headers?  ie..model and manufacturer
Motor mounts?  stock or aftermarket and where did you get em.
Belt system?  Factory later model serpentine or March?  With ac.
Oil pressure sending unit?  type and location.
I was also thinking about a 3 in exhaust with Flowmasters.... and switching to a Sanden 508 compressor for the a/c since mine was dying.
Thanks in advance for the input!
Fidd
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Re: Anyone running Big Block?
« Reply #1 on: November 11, 2010, 05:10:48 pm »
are you going to be dropped some, slammed or on bags?
Motor mounts, stock V8.
Belt system, whatever your preference it.  late model serp it good, March =$$$, what is your budget?
I didn't use a sending unit, I used a mechanical gauge.
Offline eventhorizon66
« Reply #2 on: November 11, 2010, 05:31:05 pm »
Here's a kit that adapts SBC serpentine system to a BBC.
http://www.kwikperf.com/bbc_serp_kit.html
But if you're definitely going for a Sanden compressor, you'll have to either fab your own brackets or go with an aftermarket setup like March.
'85 C10 SWB 350 700R4 TKO600
Offline TxFiddler
« Reply #3 on: November 11, 2010, 06:20:21 pm »
Not gonna drop it and the budget changes monthly.  I had thought about hitting the junk yard and getting some later model sbc serp stuff.  That would definitely free up some $ for some quality headers. And I would have to get an A4 compressor.  The March that I looked at was model 23080. It is 765.00 from Summit and does not include the Sanden.
Decisions.......decisions......
Offline Engineer
« Reply #4 on: November 14, 2010, 12:08:23 pm »
When I swapped my first BBC into my '77 4x4 I went with Headman hedders. I had fitment problems, and Headman wasn't much help. So, I tried Hooker headers and they work fine. So no more Headman hedders for me.
Also, stock small block motor mounts will work on your truck, but there is a different engine side "clamshell" for the big block. The p/n for this is 14067103, and it is still available at your local Chevy dealer. When I tried to use small block clamshells on my BBC the factory 7 blade clutch fan would rub the bottom of the BB radiator shroud. The BB clamshells lifted the engine just enough to prevent this.
I bought an entire serpentine belt assembly, alt/ps/ac etc with pulleys, and brackets for $20.00. Now I am not going to use it because of the new mission for my truck. I'll save it, and let my son use it on one of his trucks.
Look to pay more like $300.00, not $20.00 like I did for the entire BBC belt assembly.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
