Need timing help
Topic: Need timing help (Read 7305 times)
Dr_Snooz
"I like to take hammers, and just break stuff"
Need timing help
November 12, 2010, 12:50:31 am »
I just finished putting the new Edelbrock carb and Edelbrock intake on my truck. I'm ready to get it smogged, but I have a problem with the timing. If I set the timing by ear and/or a vacuum gauge, it runs great. However, when I check it with the light, it's shows that it's way advanced. So advanced that it's way off the timing tab. I estimate that it's firing at 50* BTDC according to the timing tab. If I retard it down to 12* BTDC the idle slows down and becomes rough and the engine starts making a strange plinking sound. It seems to run well at 50* BTDC and from my reading, it seems that most people time big blocks by ear, so I'm comfortable with where it's set.
However, I seem to recall that part of the CA smog check involves checking timing. If so, then I don't see it passing being so far advanced. What are my options for fixing this?
In other news, I forgot to reconnect the coil wires before I tried to start it up. When I reconnected them and tried again, I lit all the residual gas vapor in the exhaust and blew out the back of my muffler.
The upshot is that the truck sounds AWESOME now! It rumbles like an old '70s muscle car. I LOVE it!
Thanks for the help.
topp
Re: Need timing help
November 12, 2010, 07:51:35 am »
What year?
Is it TBI?
'90 Suburban TBI 350
78 Chevyrado
Z62 ON-ROAD
Site Supporters
November 12, 2010, 08:14:21 am »
Sounds like the harmonic balancer may have slipped and the timing mark is off.
topp
November 12, 2010, 08:39:27 am »
Or if it's TBI he didn't unplug the Override to base time it.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
November 12, 2010, 08:48:04 am »
I just thought of a cheat that may work.... forget the old timing mark and put you some timing tape on the balancer and make where it runs the best read what the truck should be set at.... it might work???
HIGHPLAINSDRIFTER
November 12, 2010, 10:24:23 am »
Custom exhaust always up's the resale value!
Dr_Snooz
November 12, 2010, 10:35:30 am »
Thanks 78 Chevyrado. Those are both good suggestions. I never knew that the balancer could slip and I'll bet that's what happened. I think the timing tape is a great idea. I'll try a straight smog check today. If they shoot me down, I'll be back with some timing tape (assuming they don't shoot me down for the Edelbrock carb first).
Thanks guys!
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
November 12, 2010, 12:18:47 pm »
is this your '86? i assume it is carbed?
do you have vacuum advance? I don't know if 86 had those or not but if so, was the vacuum line removed from distr. advance and plugged?
I think 87 began tbi, so I don't think there is brown wire by the master cylinder that needs to be unplugged prior to timing.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
slammed79
Thou shalt not drive stock
November 12, 2010, 12:22:23 pm »
You should be fine as long as you put an egr valve and your vacuum is still mostly right let us know how you fare.
Praise the lowered
Dr_Snooz
November 12, 2010, 11:04:31 pm »
This is my '86. No TBI. I tried timing without the vacuum line, but it didn't change anything. The line doesn't seem to have any vacuum at idle.
I took it today for the smog check and failed by miles. It's so far over on HCs that it earned the dreaded "gross polluter" designation. I hope I can fix that with some simple carb tinkering. I might have to buy an air fuel ratio gauge to get it right. They're expensive, but probably cheaper than back to back to back smog checks. I'll do a compression check and leak down test too just to rule those out.
As I suspected, they squawked about the timing. I think I'm just going to repaint the mark and be done with it.
I'll keep you posted.
1980c10
November 13, 2010, 12:14:01 am »
your distributor could be a tooth off that would put your timing mark out of place as well.
Need timing help
