Author Topic: Blazer rear quarter repair panel  (Read 6358 times)
Offline Laderhosen
« on: November 13, 2010, 01:54:44 pm »
Does anyone know if Sherman part 923-60L which is listed as 'QTR PNL RR SEC LH/RH SUBURB 73-91' will work on a Blazer. I'm most concerned about the angle of the bottom edge. Is it the same on a Suburban as on a Blazer???
I can't find any listed on their website specifically for Blazers....
http://shermanparts.com/ecat/base/dropdowns.php?last0=CHEV&last1=BLFS&make=CHEV&model=BLFS&year=1987
Sherman and   parts are the only ones I can easily get hold of.
« Last Edit: November 13, 2010, 01:57:00 pm by Laderhosen »
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Offline topp
Re: Blazer rear quarter repair panel
« Reply #1 on: November 13, 2010, 02:21:35 pm »
Right above it is the blazer/Jimmy listed as QTR PNL FT SEC LH 73-91 BLZ/JI
'90 Suburban TBI 350
Offline Laderhosen
« Reply #2 on: November 13, 2010, 02:41:49 pm »
That's for the section that goes in front of the wheelarch though...??
Offline topp
« Reply #3 on: November 13, 2010, 03:24:39 pm »
Part # 898-53BL
Is that not the same part, just for the Blazer/Jimmy????
Offline Laderhosen
« Reply #4 on: November 13, 2010, 03:35:11 pm »
Part # 898-53BL
No, click on the little blue square to the left of the part description and it shows a photo.....
Offline HAULIN IT
« Reply #5 on: November 13, 2010, 07:27:02 pm »
All of those patch panels are listed as: Truck, Blazer & Suburban. You are correct, the bottom angle will be slightly steeper for the short bed truck, Blazer, ect., compared to the long bed & Suburban, however it should not be a problem...it will just "roll under" & you can cut it off flush with the existing portion of the panel. Lorne
Offline topp
« Reply #6 on: November 13, 2010, 07:45:37 pm »
The one I am talking about does not have a little blue square next to it...
Offline Laderhosen
« Reply #7 on: November 16, 2010, 06:45:23 pm »
Cool, but surely if I "roll under" the metal it'll make the angle even shallower?? Guess I'll have to roll it out and hopefully there'll be enough sheet metal....
