Author Topic: radiator swap.  (Read 3433 times)
Offline lpapa15
  • 1979 k10 silverado
radiator swap.
« on: November 15, 2010, 09:30:00 am »
Can an 85 c20 radiator replace my 79 k10 radiator?
Offline Dr_Snooz
Re: radiator swap.
« Reply #1 on: November 15, 2010, 12:49:41 pm »
Well, in my limited experience, not even the direct-fit replacement radiators you buy specifically for your truck from Rock Auto will fit. Make sure that the width and height are roughly equivalent. Make sure the inlet and outlet are in the same spot and are the same diameter. Otherwise, you'll have to find special radiator hoses like I did. Thickness is the biggest consideration. Here in hellish hot Central California, I buy the thickest radiator I can. Also make sure the trans lines will bolt up. You may have to zip tie the fan shroud on like I did, but you can make probably it work.
