4 Wheel Drives
Which is easier/ cheaper?
Topic: Which is easier/ cheaper? (Read 7568 times)
PhoenixFear
November 16, 2010, 11:27:34 pm »
This topic has probably been covered a bunch, but I fail at searching. I want to convert my '85 C10 to 4x4. Which is easier: using the C10 frame with all the mounts and suspension, axles and whatnot from a K10, or just throwing a K10 frame under there? And I'm assuming a Suburban will be completely different? I'm having a heck of a time finding a K10 chassis, but I know axles and stuff are a dime a dozen at the junkyard. Part of me wants to also make this truck a stepside, so I'm assuming obviously it would be easier just to drop the body on that frame. That will just be a matter of preference though I guess, it is hard for me to decide between the two. Thanks.
'85 C10 longbed- daily driver
'68 GTO- frame-off
1980c10
Re: Which is easier/ cheaper?
November 17, 2010, 01:30:40 am »
sell it and buy the truck you want would be the easiest. Otherwise a parts truck would get my vote and use your body panels engine trans etc if they are better-your truck kind of becomes the part truck for a 4x4 if needed. I would explore both options depending on what's available in your area. Then you sell or part out what is left. To piece it together from a junkyard seems like extra work to me.
PhoenixFear
November 17, 2010, 01:40:48 am »
Selling my truck is kind of out of the question for now, since I doubt I'll get back close to what I have into it. I had to jump through some serious hoops and fork out some extra cash to get this truck legal in CA, but that is a different story. If I could just buy a chassis from a junkyard I would go that route, but I doubt I can. I'll start looking for a donor truck then.
'68 GTO- frame-off
November 17, 2010, 01:48:47 am »
Swapping frames would be best doing half to worry about parts not fitting. get a bushing kit redo the 4x4 frame then start to rip yours apart also you need a body lift to make it over the transfer case or since you have he donor truck you can take that center hump but then you have to make sure its the same.
PhoenixFear
November 18, 2010, 12:19:09 am »
A Suburban frame wouldn't even come close, would it?
'68 GTO- frame-off
November 18, 2010, 10:31:21 am »
Not for a frame swap but if you swapped the leafs over to convert you 4x2 to a 4x4 then it would work just need a new rear drive shaft
November 18, 2010, 01:39:51 pm »
cheapest and easiest is getting the running gear from a pickup and swap bodies.
fitz
November 25, 2010, 01:35:17 pm »
Quote from: PhoenixFear on November 18, 2010, 12:19:09 am
No, but the crossmembers, brackets, axles and drivetrain could be used to make your 2WD truck a 4x4, but like others have stated, it's a lot of work.
You would think California would have lots of clean 4x4 frames at the junkyards.
4 Wheel Drives
