Author Topic: New wheels  (Read 4684 times)
Offline frickenbored
  • 383 Beast
New wheels
« on: November 19, 2010, 05:08:00 pm »
I'm putting a 6" lift on a 1988 k5 blazer, I changed out the axles to a dana 44 in front and a 14 bolt in the rear.  Its now time to buy wheels and tires, I know I'm getting 315/75R16 tires (35") but I'm not sure on what the wheel size has to be.  All I know is that the diameter has to be 16" and they have to be 8 lug.  I want the tire to stick out about an inch from the fender but I have no clue on what the backspacing or offset has to be.
Does anyone have any suggestions on what rims to get? I know that there are thousands of these kinds of trucks on the road with a 6" lift and 35's so what type of rim are they using?
« Last Edit: November 19, 2010, 05:10:53 pm by frickenbored »
Offline malibu795
Re: New wheels
« Reply #1 on: November 20, 2010, 07:18:29 am »
4" BS will stick out more then a 4.5" and the 4" is the common
10" wide rims will run nicely as well
adam wildman
75 K25 383/400
  • 383 Beast
Re: New wheels
« Reply #2 on: November 21, 2010, 07:40:45 pm »
I've looked for 10" wide wheels but theirs a way bigger selection for cheap 8" wheels, I'm just looking for a cheap black steel wheel under $100 a piece.  So far I know I need:
Lug pattern: 8 x 6.5
Width: 8"
Diameter: 16"
Offset: ?
Backspace: maybe 4"?
Tire size:  315/75R16
