Author Topic: rear springs '80 K20  (Read 3905 times)
Offline dalea
« on: November 23, 2010, 09:36:25 pm »
I have a 80 K20 3/4 ton 350,thm400, and 14 bolt f/f rear end.   The pass side rear spring 8 leaf is collapsing so I need to replace it. I have come upon a set of 8 leaf springs from a 82 C20 3/4 ton 2wd pickup. The dimensions all are the same, so would these springs work and maintain the same ride height?
Offline Grim 82
Re: rear springs '80 K20
« Reply #1 on: November 23, 2010, 09:57:29 pm »
If they are dimensionally the same but in better shape it should be the same if not just a little bit higher ride.
