Author Topic: Need Help with part chosing  (Read 3665 times)
Offline str8bloc
  • MISTRESS
« on: November 26, 2010, 11:50:54 pm »
i have a stock 350 with a 600 edelbrock, headers, cherrybomb pro mufflers, and a holly street dominatior intake i am looking for a cam im gettinf a rebuilt set of 202s and wonderin whats a good cam i hear the 268h is ok what do yall suggest the intake is 1500 to 6500 hi rise
FaTbOy
Offline Russ130
Re: Need Help with part chosing
« Reply #1 on: November 27, 2010, 06:28:09 am »
I'd go to Comp cams site and download their software. I think it's called Camquest. You can enter the parts you have on your motor what it wil be used for and it will give several optios for different cams that will work for that application. As a bonus it has a dyno simulator so you can see what kind of numbers you can get with different cams and other parts like carbs or heads. You can also look ahead at new parts you are planning on getting are going to react with what you already have. The uses are endless and its easy to use.
