Author Topic: Gas tank relocation  (Read 24202 times)
Offline BlackDog3
Gas tank relocation
« on: December 01, 2010, 12:38:55 pm »
Hey gang, I have to come an issue with my gas tanks for my 82 K30. I want to go back to duel tanks but i dont want to use the saddle bag style. I have one tank in the back that is 25 gallons so thats not a problem. The other tank, i am not sure where to put, what tank to use or how to attach it. Anybody do this to their truck?
Thanks
Chris
1982 Chevy K30 Silverado
Constantly abused, constantly coming back for more.
Offline Canadian 4X4
Re: Gas tank relocation
« Reply #1 on: December 01, 2010, 12:45:21 pm »
you can install a blazer tank do a search on it there are several people who have done this
Offline BlackDog3
« Reply #2 on: December 01, 2010, 02:46:36 pm »
I might have been looking in the wrong place when i searched... I will keep looking to find something or just check out and see how my 98 3500 Hd is bolted in and follow how that is done.
Thanks
Chris
« Reply #3 on: December 01, 2010, 02:49:58 pm »
I am pretty sure there is a write up by Captkaos or Vile, probably in members projects
« Reply #4 on: December 01, 2010, 02:52:28 pm »
Offline BlackDog3
« Reply #5 on: December 01, 2010, 04:05:02 pm »
Thats cool, i already have that part done! I want to add a second tank that looks like the saddle bag tank but just on the inside of the frame rails. I just might have to come up with it myself.
Chris
« Reply #6 on: December 01, 2010, 07:39:11 pm »
Why do you want to move it to the inside of the rails?
I don't know of anyone that makes takes so it will have to be custom.
Offline fitz
« Reply #7 on: December 01, 2010, 07:45:57 pm »
If you run the tank inside the frame be sure to run a driveshaft loop. A bad ujoint could ruin your day real quick.
Offline BlackDog3
« Reply #8 on: December 01, 2010, 08:12:42 pm »
I just figured i would still like duel tanks, but i dont like them where they are. Just doesent seem as safe. Many other truck companies have done duel tanks on trucks with both tanks inside the frame. I figured it would be custom, just figured i would ask if anybody has done it. It does look like a tight fit, my 82 is lifted so the driveshaft isn't exactly as close as if it was stock.  I would think it would be common. I guess when GM did the recall back in the day they just switched to 1 tank or just payed us to have your truck crushed. As for the drive shaft loop, i can imagine a broken u joint would not be good!
Offline Grim 82
« Reply #9 on: December 01, 2010, 09:44:55 pm »
A couple of 16 gal. beer kegs mounted up behind the headache rack would be pretty sweet. 8)
« Reply #10 on: December 02, 2010, 09:29:07 am »
GM never did a "recall", the gave out vouchers of $1500 that you could only use toward the purchase of a newer vehicle.  There is absolutely nothing wrong with side mounted tanks.
« Reply #11 on: December 02, 2010, 10:37:15 am »
X2
I've been around these trucks all my life, seen a few t-boned hard, never saw one explode.
An auxillary tank, or upgrading to a larger suburban tank my be best option.
Offline BlackDog3
« Reply #12 on: December 02, 2010, 12:54:36 pm »
Well i guess I havent been around long enough to remember, i just hear things people tell me! So i guess having the duel tank setup the way I in-vision it wont exactly work. I am gonna see what i can do once the truck comes back from the motor swap.
Thanks
Chris
« Reply #13 on: December 02, 2010, 01:15:39 pm »
You can do whatever your mind is set to do. The dual tanks on the outside aren't that hazardous, so I wouldn't avoid it based on that. However, if dual tanks inside the frame is what you want, go for it. Thinking outside the norm has given us all many great inventions.
Offline Grim 82
« Reply #14 on: December 02, 2010, 01:54:37 pm »
This is going under a dump bed correct? The side tanks might be unsightly without anything concealing them. Maybe you can frame mount fuel cells behind the cab, under the bed, similar to the tool boxes that you see under some flatbeds.
