Author Topic: terrible idle at cold start up  (Read 18408 times)
Offline 1979C20
  • Kyle Taulton.
« on: December 06, 2010, 10:39:34 pm »
So winter rolled around and its finally getting cold. In the morning when I start up my truck, the right side of my exhaust dumps black smoke and the truck runs like its missfiring terribly. Its a 79 c20 with a 350 stock rochester qjet, headers, and true duals glasspacks. I have to rev up the engine to about 3k and hold it for like 15 seconds and it clears out and idles normal. What would cause this?
Re: terrible idle at cold start up
« Reply #1 on: December 06, 2010, 11:59:56 pm »
a choke maybe. how cold is it and what do you have as far as emissions
Offline 1979C20
  • Kyle Taulton.
« Reply #2 on: December 07, 2010, 12:04:54 am »
The choke works properly, after I get the engine to clear out, the choke keeps the idle at about 1100rpm and then when its warm, I crack the throttle and the idle drops back down to the normal 550rpm. All I have emissions wise now is the EGR. Removed emissions exhaust manifold, CAT converter, and AIR pump. Ive got headers and glasspacks now.
« Reply #3 on: December 07, 2010, 12:14:32 am »
i think not sure but i think a dirty egr can due that till it gets hot enough
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: December 07, 2010, 12:17:24 am »
That sucks! Looks like its time to buy myself a EGR block off plate and just run no emissions. I forgot to mention, I pulled my vac canisters out too.
« Reply #5 on: December 07, 2010, 12:49:15 am »
Your idle is at 550? How you do that mine is at 900 it seams to run good there. I know if my choke is on at first its ok then it will load up and smoke and act like its missing till I give it gas to open the choke even with the choke on its only about 1100
« Reply #6 on: December 07, 2010, 12:55:13 am »
just look at what other people said and 550 is about norm in park but even when I had my engine in my 86 with a th350 it would seam to only like to run 900 or higher in park so it wouldn’t stall in gear makes me wonder what I got in my engine lol
Offline 1979C20
  • Kyle Taulton.
« Reply #7 on: December 07, 2010, 12:57:02 am »
Ive got a really large cam in it, so I can set the idle lower. Its got a nice grumbly rhythm to it. Runs fine. I ran it at about 7 or 8 for a while, but it seemed really high and I was burning a lot of fuel. But it runs smooth at 550. My truck is a manual also.
Offline necromonger
« Reply #8 on: December 07, 2010, 08:28:49 am »
throw egr in trash.buy cover plate seal it good drive and be happy.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Offline 1979C20
  • Kyle Taulton.
« Reply #9 on: December 09, 2010, 11:13:22 am »
where can I buy the cover plate, how much is it, and can I buy it locally or would it be from like summit or something? And, would unhooking the vacuum line from it work in the mean time?
« Reply #10 on: December 09, 2010, 11:21:39 am »
Offline 1979C20
  • Kyle Taulton.
« Reply #11 on: December 09, 2010, 11:37:14 am »
What do you mean, irish?
Offline screamin86
« Reply #12 on: December 09, 2010, 12:01:56 pm »
I've always made the plates! I've got a couple of them I had on stock qjet manifolds laying around.I've got one on a cast intake and one on a aluminum factory intake.
86 ta:lm7 hot cam boltons
Offline 1979C20
  • Kyle Taulton.
« Reply #13 on: December 09, 2010, 12:17:59 pm »
how do you make them? Pull the egr off, trace it on some sheet metal, cut it out and silicone it on?
Offline Grim 82
« Reply #14 on: December 09, 2010, 02:58:48 pm »
Yes. Drill it before you cut it though.
