Interior & Equipment
Power Windows & Door Locks
87 Silverado power door lock prob
Topic: 87 Silverado power door lock prob (Read 49900 times)
jhcon65
December 14, 2010, 08:20:19 pm »
I have problem with the power door locks on my 87 Silverado .... they only work to lock the doors but not unlock ....I have tried different door lock switches and have pulled the ducting from under the dash to look around but , dont really know what I would be looking for ... I have a Chilton manual but its not help ,says nothing about the electrical system as far as the power doors are concerned.......any ideas
? the truck has 407,000 k miles on it , and really has no problems just trying to get all the little bugs worked out ......
87suburban
1987 Chevy suburban 3/4 ton 4x4 350 TBI/ TH400
Re: 87 Silverado power door lock prob
December 14, 2010, 08:29:29 pm »
just as a thought, have ya tried to pull the lock switches apart and tried to clean the contacts on it?
jhcon65
December 14, 2010, 08:32:50 pm »
yes , forgot to mention that.... fixed my tank selector that way took the whole switch all apart and cleaned the contacts worked great , but not for the door locks.....
87suburban
December 14, 2010, 08:38:11 pm »
did the power locks always do that, or did they work right then quit?
jhcon65
December 15, 2010, 01:54:38 am »
you know , Im not sure . As far as I can remember they USED to work but now that I think about it I dont know when they stopped....but yea , they used to , but who knows when that was ...I removed the acuators from the door and replaced them with another set I took out of another truck , but the same thing , they lock , but no unlock.....
87suburban
December 15, 2010, 08:25:25 am »
now just a thought, and im assuming you tried this already but did you check to see if it was getting power to the actuator when you tried to unlock the doors by any chance?
jhcon65
December 16, 2010, 01:31:31 am »
Actually , no I didn't check that , I figured tat if there's power to lock it there must be power to unlock
87suburban
December 16, 2010, 02:07:18 pm »
ok, it was a thought.
jaredts
December 17, 2010, 07:10:51 am »
Just because you took the switch apart and cleaned the contacts doesn't mean the switch is making contact in the lock and unlock positions. I would do as mentioned and check for 12v at the actuator when you press unlock on the switch. Either that or hot wire it and see if it moves in both directions. Its likely the switch or actuator, so it shouldn't be hard to eliminate one of them. Do you have a multimeter?
jhcon65
December 17, 2010, 01:11:41 pm »
Yes , I do have the multimeter , and will definately check that , but I have tried 2 other switches from trucks that I have gotten parts off of and same thing .... but asap i will check the switch and wires ... A much appreciated thank you in advance ..... Jeff
jhcon65
December 21, 2010, 03:40:07 pm »
OK , couldn't find the multimeter , but used a test light to test the actuator and the switch , No power to the actuator from the switch . No power when jumped from the exposed terminal on the switch to the unlock terminal going to the actuator . Traced the wires from the door up into the wire loom ... cant seem to find out if there is a relay or what up in there .....there is a a small black plug type thing that the wires from the door go int but not sure if thats a relay or just a connector .... is there anyone that knows where I can find any information about the location of the door lock relay or a fuse or someting ...up in there . So long story shorter .... no power to the door switch , and already checked the fuse block but at aloss as to where to go from here
jaredts
December 21, 2010, 03:53:39 pm »
You have power to the switch because the door lock actuator locks the doors. Use your test light to find out which wire is hot all the time at the switch. Use your test light to figure out which wire becomes hot when you press the switch to the lock position. If the remaining wire isn't hot when you press unlock on the switch your switch is bad.
jhcon65
December 23, 2010, 12:08:40 am »
If I jump the known hot wire to the lock terminal ( by passing the actual switch ) the doors lock . But if I jump the known hot wire to the unlock terminal , again bypassing the actual switch , I get nothing . This was accomplished by sliding the switch partly on the door lock wires coming out of the door. I have tried 2 other switches and still nothing . This problem is the same on both doors of the truck , lock from either side but no unlock from either side......
jaredts
December 23, 2010, 05:32:59 am »
O.K., unplug one of the actuators and run a 12v wire and touch one of the terminals with it, then touch the other. One should lock, one should unlock. If its doesn't do both then the actuator is bad. Do the same on the other door. I don't think there are any relays in the circuit. The only causes for this I have run into are bad switches, bad actuators, or corroded connectors.
autorepr
December 23, 2010, 06:40:52 am »
///////Do NOT apply 12v+ to the ACTUATOR connector/////// The terminals are normally grounded thru a relay under the dash and if you touch power to them it will be a dead short and you will have made more work for yourself.
The lock switch triggers a relay that applies power to one terminal of the lock actuators while keeping the second terminal grounded. When you flip the switch the other way the relay supplies power to the second terminal of the actuators and keeps the first terminal grounded making it unlock.
I'm guessing you have a broken wire in the doorjamb. Pull the boot back and check the wires close. The copper strands can be broken but the insulation can still be holding the wire together.
UH-OH I'M GONNA NEED A BIGGER BANDAID!!!!!
