Author Topic: header question  (Read 27791 times)
Offline polish pete
header question
« on: December 15, 2010, 10:03:23 pm »
hey guys just got some jegs headers for my 80 gmc, i cheaped out for now and i wanted to see the quality, anyways how close can i get to the plug wires before i start torching them? also there contacting the starter is that okay? or can it heat it up enough to where the starter wont turn?
and also just to ask does the smog pump get oiled from the engine?
Re: header question
« Reply #1 on: December 16, 2010, 10:32:25 am »
I think if thee wires Ain't touching your ok but you have trouble account forr movement so I try to keep it 1/2" away if I can. And heat on the starter will make it weak you want to bent that pipe away from the starter
Offline 1979C20
  • Kyle Taulton.
Re: header question
« Reply #2 on: December 16, 2010, 10:48:50 am »
My number 2 plug wire melted to my header, i pulled it off the header and changed my routing a bit and now its about 1/8th inch from the header. No problems.
Offline polish pete
Re: header question
« Reply #3 on: December 16, 2010, 04:29:35 pm »
well none of them are touching so i guess an 1/8th away wont do any major damage, and ill try to source out a micro starter if anything.
Re: header question
« Reply #4 on: December 17, 2010, 10:16:46 am »
its touching now i would think even a micro would be close and will heat soak
Re: header question
« Reply #5 on: December 18, 2010, 02:06:22 pm »
You can get a starter wrap. Works pretty good.
Offline ToddN
Re: header question
« Reply #6 on: December 18, 2010, 07:01:30 pm »
I would say you could wrap the headers too but that would cost you about what you payed for the headers.  Yeah....wrap the starter.
A government big enough to give you everything you need, is a government big enough to take everything you have.
Offline Grim 82
Re: header question
« Reply #7 on: December 18, 2010, 07:19:06 pm »
If you're concerned with spark plug wire clearance, use asbestos sleeves over the wires. Mine have been laying on the headers for a few thousand miles now and haven't even discolored. I also used a cable come-a-long to pull the header out away from the starter a bit.
Offline 4x4orbust
Re: header question
« Reply #8 on: December 18, 2010, 08:01:46 pm »
I use the same on my wires,   i went through 3 sets of wires melting to the headers before i put them on.   no problems since, been over a year.
Offline 1979C20
  • Kyle Taulton.
Re: header question
« Reply #9 on: December 18, 2010, 08:07:33 pm »
How much for the asbestos sleeves?
Offline Grim 82
Re: header question
« Reply #10 on: December 18, 2010, 08:14:50 pm »
Mine were in a 4 pack, and I think they were about $20. I only needed them for my #1 and #3 cylinders. Any parts store or race shop should have them in stock.
Re: header question
« Reply #11 on: December 19, 2010, 12:49:07 am »
even if you wrap the starter you would still have to bend the pipe away. the sleeves i see why some put them on. but i dont think they are needed, just another way for someone to make money
Offline polish pete
Re: header question
« Reply #12 on: December 19, 2010, 01:35:19 am »
i see lots of useless help in this thread, my local race shop has a full set of spark plug covers for 50 bucks might need to invest in them and ill figure something out with the starter.
Re: header question
« Reply #13 on: December 19, 2010, 08:55:52 am »
Well Pete you asked for help you got it.  now your saying its useless but if you knew what you were doing and had useful information to begin with then you wouldn't have asked for help so all you had from the get go was useless information and I/we just help you out with more useless information. So I guess your saying thanks and here I am to say hope you get it figured out and ask the guys and your race shop what to do. But remember one thing all they want is your money. If you did a search you will see its been covered with more useless information
Offline polish pete
Re: header question
« Reply #14 on: December 19, 2010, 12:43:00 pm »
oh crap im sorry man i meant to say useful info, i was half asleep when i typed that  ;D but in all seriousness this was very helpful guys sorry if i came across as an ass in that last post
i ask these questions to get real world experience instead of just some info,
