Author Topic: how do i remove the whipper motor?  (Read 9221 times)
Offline 87454westernhauler
« on: December 20, 2010, 09:17:22 am »
i have an 87 r10 chevy. i put a 79 front clip on it, and had to unbolt the whipper arm shafts. the mecanism and motor are all loose, but i need to to seperate the motor from the rest of the unit. i think loking at the back of the motor on the out put shaft the i just have to take a nut off of it, and can i use the same motor on a 79 meconism or do i need to put the motor from the 79 on it too? problem with that is that the 79 motor is bad. trying to be cheep.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline 756man
Re: how do i remove the whipper motor?
« Reply #1 on: December 20, 2010, 12:18:02 pm »
What's a whipper motor ?  Or do you mean wiper ?
1985 Chevy K-20 longstepside, 350,Turbo 400
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #2 on: December 20, 2010, 12:43:55 pm »
I'm not sure which one the 87 takes. Compare them side by side and see if they look alike I guess. I know in 78 they switched styles. Not sure after that.
« Reply #3 on: December 20, 2010, 01:53:11 pm »
do i have to seperate the motor from the arm meconisms to get them off of the cab? wiper motor! sorry
Offline bobcooter
« Reply #4 on: December 20, 2010, 02:56:31 pm »
There is a nut that attaches the wiper motor to the wiper arms where it sticks throught the hole in the firewall. Then there are three bolts that attach the wiper motor to the firewall.
« Reply #5 on: December 21, 2010, 11:11:35 am »
thats all i needed to know, thank you :)
« Reply #6 on: January 05, 2011, 04:03:47 pm »
got it all bolted in over christmas, the 87 whiper motor worked on the 79 meconism. now i need to fix the distributor and finish building my new steering coulmn out of busted 87 tilt column, a 79 non tilt and an 88 s10 blazzer non tilt column. then more rust repair!!!!! :(fun!!!!
Offline howlinwolf
« Reply #7 on: January 05, 2011, 06:10:52 pm »
westernhauler, look into google chrome, it will catch spelling mistakes with a red squiggly line. then just right click and TADA!
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
« Reply #8 on: January 06, 2011, 07:28:55 am »
sorry
Offline bobcooter
« Reply #9 on: January 07, 2011, 12:51:31 pm »
Must be some kind of steering column!
« Reply #10 on: January 11, 2011, 12:32:01 pm »
its almost together. just need to make a new push rod for the ignition switch and the high beam switch, and glue the lower bezel cover thing to the uper half of the column. it not tilt though.
Offline bobcooter
« Reply #11 on: January 11, 2011, 03:52:37 pm »
Just be careful you get it all together real good. Don't want to hit the ditch when you try to turn it! I think you could probably find one in one piece that would work fairly cheap.
« Reply #12 on: January 15, 2011, 10:05:29 am »
it work good and is functional and free ::). i bolted it in and it works good. ;)
