Author Topic: changing gears  (Read 9984 times)
Offline str8bloc
  • MISTRESS
changing gears
« on: December 22, 2010, 11:17:51 pm »
i have 3.08s right now thinking 3.73 or 4.11 what do u think itll be street/strip with a th350 and a 383
FaTbOy
Offline acefoxx
  • 84 SierraClassic stepside/85 K5 Blazer
    • Acefoxx.com
Re: changing gears
« Reply #1 on: December 22, 2010, 11:30:29 pm »
I have 3.73 in mine with a th350. My rear end is a 14 bolt with posi out of a 91 454SS. I couldn't imagine trying to drive it on the street with any shorter of a gear like 4.11s or what not. I got real good 60 ft times with them. Here are my best time slips.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
Offline ohio hab
  • 1984 C-10, 383 SBC
Re: changing gears
« Reply #2 on: December 23, 2010, 11:30:32 am »
I have 3.73's in my rear axle assembly. You can also run with the 4.11's depending on what size your tire height is, with good results and decent street driveability.
Re: changing gears
« Reply #3 on: December 23, 2010, 12:05:03 pm »
3.73 with a TH350 and a 2WD truck with less than 30" tires it going to be on the ragged edge of sanity.  I found 3.42's are the best ratio in that situation.
Offline Stewart G Griffin
Re: changing gears
« Reply #4 on: December 23, 2010, 01:23:35 pm »
Too many unknowns to tell.  i would test with the 3.08's, if there's wheelspin work on solving that first.
Offline bobcooter
  • 1979 Scottsdale C-20
Re: changing gears
« Reply #5 on: December 23, 2010, 02:30:59 pm »
4.11's will be way more "strip" than "street".
Offline str8bloc
  • MISTRESS
Re: changing gears
« Reply #6 on: December 23, 2010, 09:14:01 pm »
well the most straight line i drive is like 2 miles. the 308s are way to sluggish for me i want more umph. the street tires im using are 235 75 15 and the dots are 325 50 15
FaTbOy
Offline str8bloc
  • MISTRESS
Re: changing gears
« Reply #7 on: December 23, 2010, 10:59:02 pm »
was it a straight bolt in for the ss rear end?
FaTbOy
Offline acefoxx
    • Acefoxx.com
Re: changing gears
« Reply #8 on: December 23, 2010, 11:39:12 pm »
Nah, I just cut the pearches off and set the angel and welded on the new ones. The width was perfect though. I later switched to a coil over 4 link.
« Last Edit: December 24, 2010, 12:11:39 am by acefoxx »
http://acefoxx.com
Offline lechez71
Re: changing gears
« Reply #9 on: December 27, 2010, 09:55:49 pm »
since you dont do lots of driving on the highway, i say 4.11 but if you plan on driving it go 3.73. with the 4.11 and a 28" tire at 65mph your rpms would be around 3,300 that would suck for highway use. if it still slow off the line you need more HP. ;D what stall verter do you have?
Offline 1980c10
Re: changing gears
« Reply #10 on: December 28, 2010, 11:02:23 pm »
I had 4.11 with a 30.5" tall tire, but I had overdrive and couldn't imagine driving it much without the extra gear. You could consider an overdrive trans if you're are feeling pretty serious about the 4.11.
Offline str8bloc
  • MISTRESS
Re: changing gears
« Reply #11 on: December 29, 2010, 08:47:52 pm »
how was it on the overdrive. monster transmission is about 1000 for the setup, but i wanna drop the tranny and the gears now. then build my stroker. overall i want a 450 hp 388,700r4 and 4.11 gears.with this setup i think itll be a bad street machine.
FaTbOy
Offline lechez71
Re: changing gears
« Reply #12 on: December 29, 2010, 09:15:13 pm »
if you plan on the 700r4 go with 4.11. thats what im getting. i have a 4L60e tranny. youll have the extra gear so it wont be bad. i figured with 28" tire, 4.11s and the gearing of the 60e tranny at 65mph ill be spinning about 2200rpm.
Offline 1980c10
Re: changing gears
« Reply #13 on: December 29, 2010, 10:25:05 pm »
That sounds real close to what I had with the 4.11s and a 5 speed.
So why not build your engine and trans, drive it, see if it feels like you need a lot more?
That's my approach with my current project.
Offline str8bloc
  • MISTRESS
Re: changing gears
« Reply #14 on: December 30, 2010, 04:29:22 pm »
either way i think ima use my 3 speed with 4.11s for now
FaTbOy
