Author Topic: Auto To Manual 84 C10. Driveshaft troubles.  (Read 3493 times)
Offline CanadianC10
« on: December 23, 2010, 03:23:09 pm »
I have my saginaw 4 speed in the truck and bolted up , I knew the driveshaft from the automatic would not fit because it had the long tail shaft , so I managed to get a 2 piece driveshaft of my uncle , and I was looking at the truck it came of off ( 86 C10 with the 3 on the tree ) and it has a differant crossmember with the mount for the drive shaft , is there any other rig that has a one piece I could use , or how would I mount the two piece on mine , im trying to stay away from cutting the cross member out of the other truck :D
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
Offline 87454westernhauler
Re: Auto To Manual 84 C10. Driveshaft troubles.
« Reply #1 on: December 23, 2010, 05:29:22 pm »
go to the local junk yard and get one off a junker that is a manual trans.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline CanadianC10
« Reply #2 on: December 24, 2010, 09:27:25 am »
they use the same driveshaft that I have , the Two piece .. I figured im just gonna cut the rivets and beat them out.
1984 C10 LWB
CADDY 507
TH400
Frame twister
