Author Topic: Used my 4WD for the first time  (Read 8102 times)
Offline rainman15
  • Steve
« on: December 26, 2010, 02:20:21 pm »
Well me and the kids went out this afternoon after we received about 16inches of snow, so I finally had a need to use the 4WD.  She pulls like a tank in the snow, I loved it!
My question is how often should the differential oils front and rear and transfer case oil be changed, and what type of fluid do you guys recommend?  To my knowledge the only fluids that have ever been changed in this truck is the transmission fluid and engine oil. I'm sure after 27 years that diff gear oil has seen its better days.
84 GMC High Sierra 4x4 shortbed
09 GMC Sierra SLT
09 Mercedes Benz C-350
60 Chevrolet Impala
Offline KY..Rob
Re: Used my 4WD for the first time
« Reply #1 on: December 26, 2010, 05:21:02 pm »
80/90 is what I use. It should run just fine.
I was reading a old post from Vile, and he recommends 80/90 and 75/140 synthetic.
Rob..
Offline jackjeckel757
« Reply #2 on: December 26, 2010, 07:41:09 pm »
Nice truck! I was having fun with my 2wd down the road from you in Portsmouth, I can't believe how much snow we got!!
Offline captain carnage
« Reply #3 on: December 26, 2010, 08:13:25 pm »
Cool shots, I bet you had a blast!
Offline malibu795
« Reply #4 on: January 01, 2011, 10:01:59 pm »
not sure who had more fun the kids or the dad hahaha
adam wildman
75 K25 383/400
Offline topp
« Reply #5 on: January 02, 2011, 08:52:36 am »
if the transfer case is an NP208 use ATF in it.
'90 Suburban TBI 350
Offline KY..Rob
« Reply #6 on: January 02, 2011, 02:11:59 pm »
Good catch, Topp. I didn't even see the the "Transfer Case"
80/90 Gear Oil..Front-Rear Diffs
208 T-Case..ATF Fluid
203 T-Case..10w40
205 T-Case..80/90 Gear Oil
Yep..I think Dad had a pretty good time ;D Great looking Truck also!
Offline rainman15
  • Steve
« Reply #7 on: January 03, 2011, 03:40:13 pm »
Thanks.  Yes it was great fun.  I have so many little maintenance projects to do when it warms up, replacing all the rubber fuel lines, radiator hoses, valve guide seals, re-grounding the sending units, changing all the fluids, installing my roll-in bed liner, and more.  It is kind of overwhelming to think about it.  I'm just buying stuff now so I have all the supplies I need once it warms up.
09 GMC Sierra SLT
60 Chevrolet Impala
