Author Topic: 24V Cummins??  (Read 22459 times)
Offline 425hp87chevy
24V Cummins??
« on: December 27, 2010, 01:27:35 pm »
Has any one here ever swapped a 24v 5.9 cummins into their 73-87?  Im wondering how to go about wiring the ecm to run the engine? If it is to crazy i may look into swapping a 12v. but i really want the 24v so can someone share their info on how it's done... thanks
Re: 24V Cummins??
« Reply #1 on: December 27, 2010, 04:54:30 pm »
do a search, theres info around here.
Offline Edahall
Re: 24V Cummins??
« Reply #2 on: December 27, 2010, 05:41:58 pm »
Why the 24V Cummins?  Most people go for the 12 valve over the 24 valve for the following reasons.
1.  Don't have to deal with the ecm
2.  12 valve has a lot more potential power due to the P injection pump
3.  Stronger block - 98-01's had issues with cracked blocks
4.  Easier to modify for more power
5.  Less problematic injection system - 24 valve engines were notorious for lift pump and injection pump failures
Here's how the 12 valve fits in my square body Suburban
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline DnStClr
Re: 24V Cummins??
« Reply #3 on: December 29, 2010, 10:46:20 am »
Ditto the 12 valve.  If you do go with the 24 valve you'll be able to upgrade it better, but it would be expensive! Just be careful that you don't get one of the 53 blocks, and Edahall can explain all that to you.
Don
87 Chevy Silverado
Offline Mr Diesel
  • Aaron
Re: 24V Cummins??
« Reply #4 on: January 05, 2011, 03:14:34 pm »
Go with a 12 valve. I have a 24 valve in my '99 Dodge and I wish I had gone with a 12 valve for the same reasons listed above.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline SMiller
Re: 24V Cummins??
« Reply #5 on: January 12, 2011, 09:02:52 pm »
12-valve all the way for this, stand alone electronics wont be the hard part just a pain and tons of money.
If head flow is what you are after just remember that a 12-valve worked head will out flow a 24-valve head. Back in the day everyone was swapping to 24-valve heads to flow air, then guys started working 12-valve heads and soon found out there was a ton of room to work, big cfm!
