Author Topic: TH400 not shifting till 4,000 rpm  (Read 21679 times)
Offline Dr_Snooz
Re: TH400 not shifting till 4,000 rpm
« Reply #15 on: January 19, 2011, 10:38:08 pm »
I'm glad I asked, because I could have searched for a million years and never realized that it goes here:
I'm not sure how you guys are putting these valve bodies back in, but I had really good luck greasing the checkballs slightly like so:
The grease really held well. I tilted and bumped the valve body as I was lifting it and they stayed put through it all.
I had this spare bracket lying around, so I held the front servo piston in like so while I bolted the valve body.
I also took the opportunity to replace all the little case seals (selector shaft, governor, speedo gear, kickdown switch, etc). I got all of them but the tailshaft seal and the front and rear seals. When I drop the driveline some day, I'll get the tailshaft and rear seal.
The good news is that the truck is running again!!!! Hooray!!
Thank you all for your help!
« Last Edit: January 19, 2011, 10:42:09 pm by Dr_Snooz »
« Reply #16 on: January 22, 2011, 08:45:19 am »
FYI
Grease is NOT what you want to use in an automatic transmission. Vaseline/petroleum Jelly or trans gel.
Offline Jim Rockford
  • Banned
« Reply #17 on: January 22, 2011, 02:12:40 pm »
If that is Lubra-plate engine assy lube  He would be fine with just that little bit.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
« Reply #18 on: January 23, 2011, 10:41:10 am »
Using white grease is not an acceptable practice in assembly of automatic transmissions. You need a petroleum based low melting point lube like petroleum jelly or transjel.
Offline Dr_Snooz
« Reply #19 on: January 24, 2011, 11:16:42 am »
Oh. Good to know. Anyway, the truck passed smog today. It's running great.
Thanks again for all the help.
