Author Topic: GM BLOCK  (Read 42945 times)
Offline 305chevy c-10
GM BLOCK
« on: December 30, 2010, 05:57:36 pm »
is anybody ever heard of  a 305 gm block that can be bored to a 350 ......i was told that u can only do this with GM blocks because they are thicker ...........he said a GM 350 block can be bored to a 406 also with plenty of of metal between cyclinder walls............if this is true how do i found these what to look for as for as markings
Heartbeat of America yesterday's cheverolet
18T5C10
Offline acefoxx
  • 84 SierraClassic stepside/85 K5 Blazer
    • Acefoxx.com
Re: GM BLOCK
« Reply #1 on: December 30, 2010, 06:26:46 pm »
yeah, I don't think any of that is true. The blocks are all interchangeable but you can not bore them that big.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
Offline Da67goatman
  • Burban
Re: GM BLOCK
« Reply #2 on: December 30, 2010, 08:27:16 pm »
you can bore and stroke to increase cubes, but I don't think all of them interchange like that.  I know a 350 destroked will yeild a 327 and vice versa.
<Pitcrew>
Offline acefoxx
    • Acefoxx.com
Re: GM BLOCK
« Reply #3 on: December 30, 2010, 08:30:54 pm »
sorry, by interchange I meant heads, motor mounts, transmissions, accessories. Not displacements.
http://acefoxx.com
Offline ohio hab
  • 1984 C-10, 383 SBC
Re: GM BLOCK
« Reply #4 on: December 30, 2010, 09:00:54 pm »
Yes, motor mounts, transmissions, etc. interchange. 400 s.b. is externally balanced, where 305, 327, 350, are internally balanced. 400 heads have 2 steam holes, where others don't. Heads can interchange thou, with a modification done to fit the 400. You can use 305 heads on 350, 400, but with the small valve size of the heads, you would be hurting performance. The 305 heads can be upgraded at a great cost. All this info is about Genaration 1 s.b.c.'s.
Re: GM BLOCK
« Reply #5 on: January 01, 2011, 12:46:09 am »
to get the 406 you need to bore out a 400
Re: GM BLOCK
« Reply #6 on: January 01, 2011, 12:44:13 pm »
Whomever informed you of this knows nothing about Chevy motors.
Offline motion427
Re: GM BLOCK
« Reply #7 on: January 01, 2011, 01:01:00 pm »
I second that.
86 K10,350 Roller Cam,T350,NP205,10 bolt posi,12 bolt posi,33" tires.
85 K30,454,T400,NP205,Dana 60,14 bolt,being built now.
04 Avalanche Z71,6.0L,TVS 1900,Dynatech,Corsa,etc...
06 TBSS,AWD,6.0L,Kooks,C6 fan kit,etc...
75 Nova SS,502,T350,12 bolt
Offline Psycho71
Re: GM BLOCK
« Reply #8 on: January 01, 2011, 08:40:08 pm »
Agreed, not all SBC's are just bored and stroked differently. There are dedicated castings for the various configurations. That's why 305's go for almost nothing used, and good 350 and 400 blocks go for more.
Re: GM BLOCK
« Reply #9 on: January 09, 2011, 05:32:31 pm »
got a good deal on 350 ....i think it was tpi or tbi .dont know which .......block has 638 on it with # 14093638 .......heads have 14102193 .gm24 ...guy said it came out of 93 1500 .......has to be rebuilt though .motor was outside ....some rust on piston but they move ......i will get it bored  .030 or .040 depending on how bad the walls are .......does any body know about these casting # .......i was thinking of vortec heads .but i have a intake ,hei distributor already for regular heads ..........does anybody know how these 14102193 flow .......or buying a complete set will be cheaper than rebuilding these
on the rear of my block it has GM5.7LG  SGI .......350 i know that much
18T5C10
Offline howlinwolf
Re: GM BLOCK
« Reply #10 on: January 09, 2011, 08:50:34 pm »
wow. looks like a thought stream.
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline KY..Rob
Re: GM BLOCK
« Reply #11 on: January 09, 2011, 09:22:55 pm »
Your Block, Comes up as a 1986-94 350  The heads come up as 1986-88,  350, 1:94-1:50  EFI
Re: GM BLOCK
« Reply #12 on: January 11, 2011, 01:38:29 pm »
i know that it is a 2 bolt main ...how do i tell if its 1or 2 pc rear mains .....flat or roller cam
18T5C10
Offline Jim Rockford
  • Banned
Re: GM BLOCK
« Reply #13 on: January 11, 2011, 05:17:34 pm »
google is your friend.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Re: GM BLOCK
« Reply #14 on: January 11, 2011, 11:53:58 pm »
It is. But so are we.
