Author Topic: Which carb  (Read 15337 times)
Offline 76k104x4
Which carb
« on: January 01, 2011, 09:48:31 pm »
I want a new carb not sure if it should be Holley or Edelbrock spread or square bore or what. Now i have the factory intake and 4 bbl Qjet if i knew somebody that could id get it rebuilt and i have a Edelbrock performer intake i could put on too its for a square bore carb o and i got mechanical choke and dont want electric so what yall think i should get
Offline malibu795
Re: Which carb
« Reply #1 on: January 01, 2011, 09:50:14 pm »
what size engine?
600cfm works pretty for most DD aplications
adam wildman
75 K25 383/400
Offline 1980c10
Re: Which carb
« Reply #2 on: January 02, 2011, 01:03:27 am »
spread bore is what you have with your q-jet, a spread bore carb will generally get you better mgp with typical driving.
A square bore carb will give you quicker throttle response.
btw you can buy new/rebuilt q-jet carbs. Why do you want a manual choke carb?
They are very easy to hook up if that is your concern.
What engine do you have and what are your goals for this truck?
Offline 76k104x4
Re: Which carb
« Reply #3 on: January 02, 2011, 01:11:24 am »
i have a stock 350 except for headers and accel distributor i want manual choke because its what i have now i dont care about gas mileage at all i work in the oilfield job security ;D i use this truck as a DD but i also have a 07 GMC Z71 for going long distances and work i want throttle response,torque im goin to put a 4 inch lift and about some 35 inch tires on it not too big just right i think let me know if i left anything out thanks
Offline 1980c10
Re: Which carb
« Reply #4 on: January 02, 2011, 01:25:03 am »
You'll get better throttle response out of a square bore carb because of its larger primary throttle plates. A spread bore carb has larger secondary throttle plates so once you're moving it'll be about the same on power assuming other variables are the same. Your q-jet probably flows about 750 cfm, but imo 650-750 is a good range. All you need to hook up an electric choke is a key switched 12v wire.
Offline 76k104x4
Re: Which carb
« Reply #5 on: January 02, 2011, 01:37:56 am »
so edelbrock or holley i know yall got some opinions
Offline fitz
Re: Which carb
« Reply #6 on: January 02, 2011, 07:25:45 am »
For a daily driver/mild small block I think a Edelbrock 600 is the way to go.
Bolt it on, follow the instructions to adjust the idle mixture screws, and your done.
I've run many of these carbs on different small block powered vehicles over the years and was always happy with them.
Offline TandocTools
Re: Which carb
« Reply #7 on: January 02, 2011, 07:35:45 am »
I'm really liking the Edelbrock Thunder AVS 650 CFM I put on my C15!  Very good response right out of the box and in the Spring I'll buy their tuning kit and dial it in even more.
Offline malibu795
Re: Which carb
« Reply #8 on: January 02, 2011, 09:09:20 am »
i got the performer 600
IMO erdelbrock is more setup for DD then holey is due how they are designed.
adam wildman
75 K25 383/400
Offline ohio hab
  • 1984 C-10, 383 SBC
Re: Which carb
« Reply #9 on: January 02, 2011, 09:31:00 am »
Holley 600, Electric Choke.
Offline three8six
Re: Which carb
« Reply #10 on: January 02, 2011, 09:38:03 am »
Holley would be my preferred carburetor. I have an edelbrock sitting on the shelf now for a reason.
Offline 1980c10
Re: Which carb
« Reply #11 on: January 02, 2011, 09:50:34 am »
If this is an engine that you may do more modifications to; I would go with a 750 cfm, my preference is  holley after a q-jet but they all work, the tune is probably more important. Most people prefer carbs they have experience with or have seen work well. For a 4x4 I have heard of poor preference due to running the truck at steep angles for either a holley or edelbrock although I forget which was better. maybe someone here has heard about this?
Re: Which carb
« Reply #12 on: January 02, 2011, 01:20:06 pm »
For a stock app, a 750 holley is WAY to big even if you plan to upgrade later.
a Q-jet CAN flow 750 but it operates on Vacuum, it will only draw in what it can pull in.
I would never run a Holley on a 4x4 due to float design, but if it is going to be flat roads shouldn't be a problem.
Offline 1980c10
Re: Which carb
« Reply #13 on: January 02, 2011, 01:57:25 pm »
thanks capt. it was the holley float design I have heard of giving problems.
« Last Edit: January 02, 2011, 02:01:29 pm by 1980c10 »
Re: Which carb
« Reply #14 on: January 05, 2011, 10:59:03 pm »
     A edelbrock 1605 is a 600 cfm with a manual choke.  I just rebuilt the one on my truck, they are easy.  The PO put it on for some reason, I am going to change it back to a q-jet when I find one in the wrecking yard.  The edelbrock is very easy to work on and tune.
