Author Topic: 2011- What are you going to do to your truck this year?  (Read 18490 times)
Offline N2TRUX
« on: January 03, 2011, 12:11:58 pm »
Now that the holidays are over, and 2011 is officially here its time to ask "- What are you going to do to your truck this year?". I have set several goals for a update to my 77 Cheyenne. I hope to have a rendering available soon, so I will keep the details quiet until then.
Meanwhile, What are you going to do to your truck this year?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 2011- What are you going to do to your truck this year?
« Reply #1 on: January 03, 2011, 12:15:24 pm »
I may wash them.  Maybe.  It's been about two years since i washed my 'burb, and about 4 yrs for my '79 Big 10 pick up.  ;D
Offline Da67goatman
  • Burban
« Reply #2 on: January 03, 2011, 01:01:35 pm »
This year will be Body work and Paint, then accessorizing, Center caps, trim rings, cab lights, Running Boards, Mudflaps, Tailights, Finish stereo, ect.  Might even get my dream trans built, wouldn't bank on it though.
<Pitcrew>
Offline jaredts
« Reply #3 on: January 03, 2011, 01:01:47 pm »
I have one final rusty spot on the driver's side bedside to weld in a patch panel.  Just minor body work from there and finally get my paint on.  If that goes well I may get an engine put in before the year's out.  We'll see, but either way my truck should be happy after this year!
Offline lechez71
« Reply #4 on: January 03, 2011, 01:04:57 pm »
4.11gears, 3600 stall, LT headers, magnaflows, rebuild suspension, bucketseats.
Offline Grim 82
« Reply #5 on: January 03, 2011, 01:12:24 pm »
Swap axles for some lower gears, install rear posi, new paint, build a console with some cup holders, custom bumpers, hitch, and spare tire mount, possibly hook the A/C back up.
Offline txchainsawgogi
« Reply #6 on: January 03, 2011, 01:52:27 pm »
New tires and paint FINALLY
Offline thirsty
    • Suitor's Garage
« Reply #7 on: January 03, 2011, 02:47:46 pm »
I want to get the body work done to my cab then put it back together and make it run so I don't have to push it in and out of the garage anymore  ;D
Offline Layne
« Reply #8 on: January 03, 2011, 04:16:17 pm »
I'd like to save up money to rebuild the motor in Emmy, but with all the issues my 88 is giving me I might be blowing my money on that. At least I working on a truck (just not a 73-87) :)
Offline KY..Rob
« Reply #9 on: January 03, 2011, 05:33:28 pm »
I've been stockpiling parts all summer, So I'm hoping to get the cab back together, finish the the frame repair, Rebuild the SM465 and the 205. I would also like to change the oil pan gasket and sandblast my headers, change the core support. It should be a good year ;D
« Reply #10 on: January 03, 2011, 05:52:40 pm »
     My 74 k10 step side I plan on mechanically having it perfect.  My 81 k10 fleetside, fix the blown head gasket and the tranny leak so I can get it on the road again.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #11 on: January 03, 2011, 06:58:13 pm »
Body work and paint, new chrome front bumper, new front turn signal and side marker lamps and a Rhino Lining in the bed. Then just cruise and look good till my wife makes me get started on the house. LOL!
Offline greg1984GMC
« Reply #12 on: January 03, 2011, 07:11:29 pm »
Doing a frame off paint job. New bed wood, new roll pan and lights, New grill, bumper and trim.
Live to Ride-----Ride to live.
Offline 1980c10
« Reply #13 on: January 03, 2011, 07:35:55 pm »
I will be removing my inline 6 and sm465 to make room for a new 350 and 5 speed. After that is up and running I will be adding a 12" memphis shallow sub and two new amps to the stereo. I am hoping to have that done by July, from there who knows....All normal practicality and rational money handling goes out of the window when it comes to my truck.
« Reply #14 on: January 03, 2011, 08:05:23 pm »
Boy what a list: First is to get the Diesel ex cab running again, and hopefully have it recleared. Then I am wanting to get the 427/th400 combo put in my 76 choptop snb and get it running. Just gonna ratrod it out for now so I can drive it. Then it'll be bouncing around on body work between oldyellers truck, the extended crewcab, and the tan/black GMC. Thats the plan anyway.
