Author Topic: single tank setup help  (Read 11679 times)
Re: single tank setup help
« Reply #15 on: January 11, 2011, 04:33:22 pm »
are you still running the fuel level through the selector?
It needs the tank wire to the sending unit, and a ground to the frame.
Explain "screwy"
Offline txchainsawgogi
« Reply #16 on: January 11, 2011, 05:40:01 pm »
The fuel level is going through the switch still. It currently says its almost full and it isn't,,, sometimes the needle sways back and forth a bit too.
I want to get rid of the switch and the extra wiring but don't know how, and none of it is in mymanual.
« Reply #17 on: January 14, 2011, 08:23:46 pm »
For the sender, you just need 1 wire going from before the switch, down to the sending unit.
« Reply #18 on: January 17, 2011, 11:50:46 am »
hmm... how do I identify the correct wire?
Offline ccz145a
« Reply #19 on: January 17, 2011, 12:06:16 pm »
it's usually pink or pink/wht. The schematic for your year should have color abbeviations for the wire.
« Reply #20 on: January 17, 2011, 01:24:18 pm »
Dang I didn't see it in my manual...ill look again though.
Offline ccz145a
« Reply #21 on: January 18, 2011, 07:53:51 am »
Look in the tech section in this forum, there are electrical diagrams for most year models.
« Reply #22 on: January 22, 2011, 09:41:49 pm »
im gonna try and get it taken care of tomorrow... i checked the diagram for my year and still couldnt correctly identify which one im looking for.
its really hard to view things like that on a cell phone haha. anyways if i do find it what am i going to do exactly? im a little confused how the fuel gauge works i guess. the pink or pink/white wire goes from the gauge to the sending unit? whats in between? i guess i might be able to figure out when im looking at it but id like to get a vague idea before i start cutting wires!
« Reply #23 on: January 22, 2011, 09:43:01 pm »
or even some help on going around the stock wiring for now, just bypassing it and wiring up the gauge to the single tank until i figure out how to correctly eliminate all the non-used wiring...if thats possible.
« Reply #24 on: January 25, 2011, 06:05:04 pm »
Anything?!
« Reply #25 on: January 25, 2011, 06:20:51 pm »
look at the wiring schematic and build your own harness.
