Author Topic: I need vacuum help  (Read 3370 times)
Offline Da67goatman
  • Burban
I need vacuum help
« on: January 05, 2011, 07:18:20 pm »
What is the best way to CAUSE a vacuum leak?  Yes I know this is opposite of what everyone else does.  I need to have vacuum bleeddown in rubber hose.  Should I put a slit in it? A hole?  I need ideas.  Thanks.
<Pitcrew>
Offline Grim 82
Re: I need vacuum help
« Reply #1 on: January 05, 2011, 07:44:54 pm »
Unplug one. Try the HVAC line.
Offline Da67goatman
  • Burban
« Reply #2 on: January 05, 2011, 09:26:28 pm »
Never mind I re-routed some stuff and used a pre-existing vent.
<Pitcrew>
Offline DnStClr
« Reply #3 on: January 06, 2011, 04:30:08 pm »
Why did you need a leak?
Don
87 Chevy Silverado
Offline Da67goatman
  • Burban
« Reply #4 on: January 06, 2011, 04:47:37 pm »
I have vacuum operated water valves, and vacuum closes them.  in order for me to have heat I had to kill vacuum to them, but it wouldn't bleed off, it retained the vacuum.  I rerouted lines and it all worked out, no holes needed.
<Pitcrew>
