Author Topic: 3 on the tree to floor shifter.  (Read 12063 times)
Offline Slooby
« on: January 05, 2011, 08:48:10 pm »
just wondering which is the easiest way to do the swap and what kit is the best to buy, I want to swap it over for the time being til I can get a better trans.
Offline Brady
Re: 3 on the tree to floor shifter.
« Reply #1 on: February 02, 2011, 06:30:59 pm »
I just ran across this post.  I have a '73 K-10 with a Hurst floor shifter.  The problem is that it is a generic, one size fits all, shifter.  It seems no one makes one specifically for the Chevy 3-speed.  It doesn't work very well; you have to shift very deliberately to keep from winding up jammed between gears.  If you are going to change out the transmission for a 4-speed I would just wait, unless there is something wrong with your column shift.
Offline 79chevykid
« Reply #2 on: February 02, 2011, 08:58:15 pm »
on the truck i bought someone did the switch, i dont know what brand it is but it worked.
1979 short box chevy custom deluxe (project)
« Reply #3 on: February 02, 2011, 10:32:00 pm »
I have a Hurst shifter that works just fine for me. I think this is the one. Came with the truck so im not positive.
http://www.summitracing.com/parts/HUU-3838520/
« Reply #4 on: February 02, 2011, 10:47:31 pm »
I have had good quality hurst 3 speed shifters that worked great.  I also have one of those cheapie Indy shifters on my 86 that the PO installed, what a piece of garbage.  This is one case where you get what you pay for...  But I for one would fix my column shift if I had all the rest of the stock linkage.
« Reply #5 on: February 03, 2011, 01:15:21 pm »
The ones I have used in the past were Hurst.
« Reply #6 on: February 03, 2011, 10:23:33 pm »
I have a bunch of stock linkages that might work, I kept getting the wrong ones ha. Or check the junk yard.
« Reply #7 on: February 04, 2011, 03:24:02 pm »
My shifter collar is broken so I need everything.  I haven't found even a bad one in the yards by me...
