4x blazer to 2wd
Topic: 4x blazer to 2wd (Read 7810 times)
seventyx3
4x blazer to 2wd
January 05, 2011, 08:51:19 pm »
Could a four wheel drive blazer be converted to 2wd with the front crossmember spindles, box, etc. from a 2wd truck as a direct bolt on? 2wd blazers are rare, but four wheelers are common. Would this also affect drive shaft length?
Re: 4x blazer to 2wd
January 05, 2011, 08:54:41 pm »
The front can, the rear cannot. BUT you can lower the rear of the blazer some and make it 4x2. Driveshaft would be different as you would have to get a 4x2 driveshaft.
I am gathering parts now to convert my 4x4 Blazer to 4x2. (I also could go the easy route as I already have a 4x2 Jimmy)
seventyx3
January 05, 2011, 09:26:02 pm »
Would I still need to find a 2wd blazer reared (leaf springs) to make it "normal"? What would be the best way to lower it? I'm wanting a factory ride height.
January 05, 2011, 10:36:31 pm »
Factory ride height you should be fine with the 4x4 stuff, just may need lower springs.
74k20
January 06, 2011, 01:20:29 am »
Out of the box idea here.
Could you just "lower" the whole 4x4 and make it a lowrider. Adjust all the drive shafts and put on street wheels/tires. Go for a sleeper look that could be funtional in city snow, like an AWD car.
January 06, 2011, 02:02:52 pm »
NO lowering a solid axle is not possible.
Da67goatman
Site Supporters
Burban
January 06, 2011, 04:50:31 pm »
I don't see why you couldn't do a flip kit front and rear. You would have to adjust your steering, shorten shafts ect.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
January 06, 2011, 05:46:01 pm »
Even if that was possible, it would put the steering in the middle of the axle tube. Trust me, lowering a 4x4 is not possible.
slammed79
Thou shalt not drive stock
January 06, 2011, 06:13:10 pm »
Capt is right, there isn't any way to lower a straight axle 4x4, cept for maybe hydrualic steering, even then... why?
Praise the lowered
74k20
January 06, 2011, 07:51:09 pm »
Ok ok... guess that idea was waaaay too far "out of the box"
You make good points with the solid axle thing. It was way too late to think properly, couldn't sleep (couldn't think either).
Da67goatman
Site Supporters
Burban
January 06, 2011, 09:22:40 pm »
Make it a 60's gasser tribute, you can make it 2wd or 4wd and keep solid axles, leafs ect. That would be outrageous, fender headers, mag wheels.
<Pitcrew>
4x blazer to 2wd
