Author Topic: exhaust pipe size?  (Read 6416 times)
Offline sphnyx991
exhaust pipe size?
« on: January 06, 2011, 11:41:41 pm »
so i got a chevy zz4 350 motor in a my 1984 chevy k20 with a 6 inch lift with 35" tires, this is a new motor and i havnt fired it yet and i need to get some exhaust for it, i have mufflers for it already but i saw summit sells a header back exhaust system for it minus mufflers but it only comes in 2 1/4" piping, would this be suitible for my mild 350 or would running 2 1/2" piping be worth the extra work of fabbing up my own system. i have fabbed a couple systems in the past but like the idea of a bolt up system. any info would be appreciated, thanks
Offline lechez71
Re: exhaust pipe size?
« Reply #1 on: January 07, 2011, 01:21:02 am »
go for 2 1/2" pipe or even 3" if its not going to be mandrel bent, IMO 2 1/4 is to small.
« Reply #2 on: January 07, 2011, 03:01:25 am »
Go 2.5
Offline screamin86
« Reply #3 on: January 07, 2011, 03:50:49 am »
2.5 will be plenty I believe dual 2.5 will support somewhere in the 450hp+/- range with no problem anything over that is a overkill.
86 ta:lm7 hot cam boltons
Offline Jim Rockford
  • Banned
« Reply #4 on: January 11, 2011, 07:54:46 am »
2 1/2 vote here also, but if you went with a 3 inch single you would keep alot more torque. Also  have you changed the gears in your axles for those tires? That will make even a good motor feel like a dog .
« Last Edit: January 11, 2011, 05:25:42 pm by Jim Rockford »
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline screamin86
« Reply #5 on: January 11, 2011, 12:50:34 pm »
I run a single 3in and couldn't be happier.
« Reply #6 on: January 14, 2011, 11:30:24 pm »
     The above info is all good, duals = 2.5"  or single = 3"
