Author Topic: please someone shed some light on what could be wrong with my suspension!  (Read 31395 times)
Re: please someone shed some light on what could be wrong with my suspension!
« Reply #30 on: January 11, 2011, 09:11:38 pm »
nevermind on the remove a leaf in the rear thing, looks like  it's been done already.   if not then they are lowered leafs in the rear.the shackle and all looks like stock.
     I would have to agree, the p.o. must have bought lowered springs, they do not look stock to me..
Offline rwhit57
« Reply #31 on: January 11, 2011, 11:54:47 pm »
No doubt the guys are correct on the bumpstop, when I lower one I cut the entire bumpstop pad off the lower a-arm. Man that bumpstop that's on there is huge.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline bigdogck
« Reply #32 on: January 12, 2011, 12:13:45 am »
if no one caught it the rear end has been fliped probably drop spindels check exhaust & rear frame clerance
Offline lechez71
« Reply #33 on: January 12, 2011, 01:31:58 am »
how has the rearend been fliped? are the u bolts fliped?
Offline 4x4orbust
« Reply #34 on: January 12, 2011, 07:48:39 am »
looks just like my and every other truck i've seen, not sure how it's been flipped?  springs are still on top of the axle...
Offline three8six
« Reply #35 on: January 12, 2011, 10:40:47 am »
If you want more travel cut the factory rear bump stop bracket off, and get an aftermarket bumpstop thats short.  I had to do that when I flipped my rear end. It was like 1/2 inch of travel before I did that.
Offline royo
« Reply #36 on: January 12, 2011, 11:35:22 am »
What kind of motor is in this truck? sorry if i missed it .  The front springs look fairly new . but they look like some big block springs that i have around here some where .
Offline lechez71
« Reply #37 on: January 12, 2011, 01:49:52 pm »
the truck has an LSX motor, the springs are new just put them on 5 days ago. they are DJM springs.
Offline royo
« Reply #38 on: January 12, 2011, 04:45:38 pm »
Can you push down on one of the front fenders . And tell me what happens. how much does it move
Offline lechez71
« Reply #39 on: January 12, 2011, 05:51:19 pm »
heres a vid of pushing on the fender its real stiff because it has new springs and shocks
dont seem to hit, but im still gonna put grease on the bump stop.
« Last Edit: January 12, 2011, 05:52:51 pm by lechez71 »
Offline rwhit57
« Reply #40 on: January 12, 2011, 09:27:18 pm »
I can almost guarantee you that bumpstop is hitting and hitting hard. There is not enough space for that thing. Here is a pic of my susp prior to blasting and painting, notice the bumpstop and pad are gone. This is because when you lower one it hits, the one you have is even bigger than stock.
Randy from Okla
« Reply #41 on: January 14, 2011, 08:01:22 pm »
The rear on the truck is NOT flipped.  Flipped would mean the axle is on top of the springs.  It also doesn't look lowered to me in the rear at all.
based on your video, you are bottoming out the front, you need to cut the bumpstop "stand" off like rwhit57 shows in his picture.
« Reply #42 on: January 15, 2011, 08:56:01 am »
It looks like the bump stops are tapered like they are universal so you can cut them on the lines to make them fit
Offline lechez71
« Reply #43 on: January 15, 2011, 02:15:59 pm »
yes they are universal and tappered. just havent got the chance to cut them its been raining for two days.
