Author Topic: 1985 GMC Suburban rear tail gate window  (Read 12222 times)
Offline harkz28
« on: January 09, 2011, 07:41:18 pm »
Please,  a little help. I replaced the track roller and pins for the tailgate window. I also replaced the rubber sheet that goes in the channel that the window slides into on the bottom. The problem is when I role down the window the window comes out of the track and hangs up in the weather stripping. Should the window be glued in the track or ??? How does the window stay tight in the channel?  Thanks Steve
Offline harkz28
Re: 1985 GMC Suburban rear tail gate window
« Reply #1 on: January 10, 2011, 06:50:02 pm »
Found out there is special glue for window to channe,  now the question do I still use the rubber sheeting I bought at   Or just glue the glass the the metal channel?
« Reply #2 on: January 11, 2011, 03:57:07 pm »
The glass is sandwich in the channel around a rubber sleeve.
Offline Psycho71
« Reply #3 on: January 12, 2011, 02:19:39 pm »
Yep, I'd glue it into the rubber channel, then glue the channel to the metal. No metal touching the glass would be my way of thinking.
Offline harkz28
« Reply #4 on: January 13, 2011, 09:57:37 pm »
Thanks for the replies! I had already glued without the rubber. I used primer with urethane. The glass shop told me to not use the rubber and put primer on both side of the glass and in the sash then gob the urethane (black gunk glue) in the sash then shove the glass in close the window and don't touch it for 3 days!!
« Reply #5 on: January 14, 2011, 07:35:09 pm »
You can do it that way also.
Offline harkz28
« Reply #6 on: January 16, 2011, 09:33:37 am »
4 days and glue is holding!!! Is there a safety switch and relay schematic out there for the electric tailgate window?
« Reply #7 on: January 16, 2011, 09:16:45 pm »
In the tech section.
Offline caddychris
« Reply #8 on: January 17, 2011, 10:40:00 am »
try and find a whole tailgate at a junkie, thats what i did and it words purrrfect
