Author Topic: 87 R10 parking brake pedal  (Read 12658 times)
Offline mdws1987
« on: January 10, 2011, 02:06:47 am »
The parking brake pedal on my 87 R10 will not return to the up position. The rear cables are new. I can pull it up while pulling out the release handle. Is there a spring on the assembly or maybe I need a replacement???
Offline topp
Re: 87 R10 parking brake pedal
« Reply #1 on: January 10, 2011, 07:54:38 am »
Sounds like the front part of the cable is hanging up.
Have you replaced that?
Did you lube it?
'90 Suburban TBI 350
« Reply #2 on: January 10, 2011, 12:31:40 pm »
What about the return spring on the pedal? Grease the pivot point too.
Offline mdws1987
« Reply #3 on: January 10, 2011, 01:35:04 pm »
The front cable was not replaced. But it does move freely. The back cables were bad and replaced. I will try to check the spring as suggested.... Thanks..
Offline screamin86
« Reply #4 on: January 10, 2011, 04:50:23 pm »
I'd like to know the answer to this also as my parking brake on my 86 does the same thing which causes my dash brake light to stay on :/
86 ta:lm7 hot cam boltons
Offline PromiseKeeper
« Reply #5 on: January 13, 2011, 09:04:10 am »
I'll be interested to see more about this...sounds like a common problem. When I bought mine, the pedal was tied up with twine.  ??? Haven't tackled that one yet. I figured that the first time I tried to set the brake, it would lock up and stay there.  ::) Does anyone know of some good pictures of the assembly? I only see a very small spring and wonder if my return spring is gone?
« Reply #6 on: January 14, 2011, 11:09:33 pm »
     x2 on the spring, should have a pretty stiff spring on the pedal assy itself.  When you pull the handle to release the locking mechanism, the spring is what brings the pedal back up.
Offline 1980c10
« Reply #7 on: January 15, 2011, 09:18:35 am »
Mine was like this; I just had to tighten the cable.
Offline roger97338
« Reply #8 on: April 15, 2011, 11:31:38 pm »
I know this is an old thread, but I'm having the same parking brake issue in my '75. The spring on my pedal assembly is evidently missing, since I don't see one. The diagram in my Chiltons manual is very tiny and doesn't show me what I need to know. Does anyone have a picture of theirs, so I know what the spring looks like (it went SOME where....maybe it made it's way from the ground to my spring drawer.) and where it goes?
Offline 1980c10
« Reply #9 on: April 16, 2011, 12:08:30 am »
This is in front of the transmission crossmember. Tighten the nut until the pedal returns to the right position.
The spring is near the back brakes.
« Reply #10 on: April 16, 2011, 10:10:19 am »
This is what fixed mine! No big return spring near the pedal.
Offline roger97338
« Reply #11 on: April 16, 2011, 06:25:38 pm »
Ah, I misunderstood.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #12 on: April 16, 2011, 07:03:10 pm »
Just watch when tightening it up it doesn't get tight enough to make the brakes drag when its off.
Offline 1979C20
  • Kyle Taulton.
« Reply #13 on: June 21, 2011, 04:35:21 pm »
This is a little old, but i was always taught to depress the pedal 3 clicks then tighten the nut until the cable is tight.
