Author Topic: 1991 V3500 - The Only Minivan I Will Ever Own  (Read 113891 times)
Offline bfofish
Re: 1991 V3500 - The Only Minivan I Will Ever Own
« Reply #15 on: January 29, 2011, 04:33:52 pm »
My 89 Blazer & 91 Suburban had the fender mounted antenna.
I believe yours should have had the antenna on the right front fender originally as well.
Offline ehjorten
« Reply #16 on: January 29, 2011, 05:43:58 pm »
Looks to have had originally the windshield antenna.  The stock dash has the relief for the button connection  at the base of the windshield.  The windshield in it now does not have it and the old antenna lead goes uptowards that area.  Think I would like a stock fender mount though!
-Erik-
« Reply #17 on: January 31, 2011, 09:34:39 pm »
All dashes have the relief for the Button.
Offline ehjorten
« Reply #18 on: February 14, 2011, 04:12:38 pm »
Is there a good source for the fender mounted antenna or is it salvage?
-Erik-
« Reply #19 on: February 14, 2011, 05:02:51 pm »
I haven't ever found one aftermarket,  BUT I much rather have the one in the glass.  Does yours have a fender mount?
Offline ehjorten
« Reply #20 on: February 15, 2011, 07:15:21 am »
Mine right now has this short, flexible, rubber whip antenna mounted to the center of the roof right now.  Want to get rid of that, patch the hole up and go back to a stock configuration.  My '77 has the wires in the windshield, but thought I might like the fender mount as I have heard that reception in a crew cab is highly directional with the antenna in the windshield.  Thought I might like a clean windshield as the one that is in there now doesn't have the wires.  I guess I am open to discussion about this.
-Erik-
« Reply #21 on: February 16, 2011, 06:34:20 pm »
My Crew has the mast, my Burb has it in the windshield.  Both pickup radio fine.
Offline three8six
« Reply #22 on: February 20, 2011, 12:14:14 am »
I'd get a fender mount and then mount it on the inside of your hood attached to the inside of your fender laying down. My buddy did that on a newer silverado to shave the antennae off of it and to still be able to get signal.
Offline bowtieguy79
« Reply #23 on: May 09, 2011, 10:18:07 pm »
Love ur truck!!
1990 V30 Crew Cab - 383 Stroker, 4 speed, 3.73 gears, 6" Pro Comp
Future plans - New long bed, Chrome Double/single Roll bar / six KC Lights, 35x12.5-15 BFG MT, 15x12 AR wheels, late 80's style grille, Black paint job
Offline 87454westernhauler
« Reply #24 on: May 10, 2011, 05:57:30 pm »
I'd be tempted to get a minivan if they looked like that  ;D
X 2 ;D
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline Engineer
« Reply #25 on: May 10, 2011, 07:09:56 pm »
Sweet rig
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Offline BigRock
« Reply #27 on: May 18, 2011, 07:30:24 am »
Beautiful Truck!
Offline ehjorten
« Reply #28 on: July 05, 2011, 09:11:12 am »
Got my quick-release mudflaps mounted a while back.  Haven't done much more work to the truck as I have been spending all of my free time working on getting my shop finished.
The setup is from Shocker Motorsports.  Not sure exactly how I feel about the clear flaps, but they were cheaper than the black ones.  I can always make some black rubber ones later out of a sheet of masticated rubber.
I wanted something that was well designed, easily removeable, and did not screw into the body work (I have seen too many mudflaps screwed into the wheelwell flange that rip-out the screws, plus they all create small areas where debris can collect and it creates a nasty pultice corrosion spot).
About the only thing I wish is that the drop tubes were a little tighter to the bottom of the bed-sides.  I might have to modify the tubes to get them to pull up closer to the bed.
Please excuse the crappy cellphone pictures!
« Last Edit: January 05, 2015, 09:44:46 am by ehjorten »
-Erik-
Offline big bear
« Reply #29 on: July 05, 2011, 05:21:40 pm »
love the truck.  sooooo awesome.  looks great man.
