Author Topic: body mount bolt kit  (Read 34601 times)
Re: body mount bolt kit
« Reply #15 on: February 19, 2011, 08:58:30 am »
Fold the metal out of the way and get the retaining nut out. You could reuse it after getting the broken bolt out, or just weld in a regular hex nut.
Offline ToddN
« Reply #16 on: February 19, 2011, 09:18:39 am »
The retaining nut is loose.  But fused to the bolt.  Should I just pound it up through the bottom side?  Ive got vise grips down on the bolt and a box wrench going on a right angle to the vise grips and the thing wont budge.  The funny thing is...this is only one of four. :'(
A government big enough to give you everything you need, is a government big enough to take everything you have.
Offline thirsty
    • Suitor's Garage
« Reply #17 on: February 19, 2011, 09:27:35 am »
Probably stuck in the mount itself too ToddN. I would drive it up thru and use a new hex nut like Blazin suggested.
Offline KY..Rob
« Reply #18 on: February 19, 2011, 09:31:45 am »
The nut is wrapped in a metal cage. If you fold the metal retainers up and out of the way Like Blazin is saying, you should be able to pick it up out of the floor support. Get a hammer and screwdriver and pry the metal up, put your vice grips on the broken bolt and pull it straight up into the cab with you.
Offline ToddN
« Reply #19 on: February 19, 2011, 09:43:44 am »
O.K.  I'll try that.  Thanx for the help guys. :D
Offline ToddN
« Reply #20 on: February 19, 2011, 10:23:58 am »
Thanx for helping me with the concept.  I had no idea that I had to fold back those two tabs (the cage) to pull that retaining nut up and out.  Well, theres one down.  Three to go!  Thanx again.  Those two tabs werent fun either by the way.  My knuckes look like I got into a bar fight. ;D
Offline ToddN
« Reply #21 on: February 19, 2011, 04:46:01 pm »
I'll  throw this in there just in case some other newbie is dealing with this job.  I measured from underneath the edge of the body to the rear cab bolt.  Then I went in the cab and went in the same distance and drilled a peep hole.  I then soaked the heck out of the retaining nut through the small hole with PB Blaster.  I'm gonna let it sit over night and see if that helps with the rear.  I'll put  in a small plug in the hole when I'm done.
Offline thirsty
    • Suitor's Garage
« Reply #22 on: February 19, 2011, 04:50:58 pm »
Just thought I would throw this out there for you. I have had better luck getting those out with a breaker bar rather then an air wrench.
Offline ToddN
« Reply #23 on: February 19, 2011, 04:57:41 pm »
Yeah.   I havent put an impact wrench to it.  I'm using an old school tire iron (four way) with a three foot pipe extension.
« Reply #24 on: February 20, 2011, 12:21:29 am »
As far as covering those holes back up I usually just rivet a patch over the holes. That way if you want to get inthere again you just drill out the rivits.
Offline ToddN
« Reply #25 on: February 20, 2011, 07:29:12 pm »
Well
I only had a couple hours to work on my truck today.  In that two hours I frigged around with ONE mount.  I think and I stress think, that the bolt is going to come out in one piece but I cant pull it out. I literally spent two hours trying differant tools to gain leverage  to pry it down.  It's just turning freely.  I even tried jacking the body about an inch and the bolt just rises with it.  I turn it, bang on it, pull down on it, pry it....just aint comeing down.  Any tips?
Offline ToddN
« Reply #26 on: February 20, 2011, 07:30:20 pm »
I know, I know.  Cut another hole. ;D
Offline ToddN
« Reply #27 on: February 23, 2011, 09:57:37 am »
http://www.brotherstrucks.com/prodinfo.asp?number=CMS8487
So I finally got my bolts out.  All four ended up breaking.  This is the cab kit I got.  My old ones were eo distorted that they are unrecognizable.  Could someone help me out with which ones go where?  Sorry to be a PIA with this but I have never done them before.  Thanx for anyones time. :)
Offline KY..Rob
« Reply #28 on: February 23, 2011, 08:57:05 pm »
The two on the back top row go with the two smaller ones on the left, They go under your floor. The four on the right go together under the back of the cab.
Offline ToddN
« Reply #29 on: February 23, 2011, 09:05:46 pm »
Thats what I thought.  Just wanted to make sure.  I appreciate it.
