Author Topic: trucks squeeling like a pig...kinda  (Read 3216 times)
Offline 4x4orbust
« on: January 13, 2011, 03:57:30 pm »
....and it's coming from under the trans tunnel.
 My 82 K10 is my plow truck. (350, th350, np208, 10 bolts)    while out plowing in yesterdays storm, i had a few instances where this happened.  only in reverse, and only under moderate to heavy throttle to back out of the snow pile.  does not do it in 4 lo, only 4 hi.   almost sounded like the noise the plow pump makes after it's all the way up.
 also at times i had a shudder in the same situation,  but not accompanied by the squeal, i can't tell if thats the tires or not (swamper tsl's 33x12.5)
absolutely no other issues otherwise.  shifts fine, drives as it should.
i was thinking it may be a clutch of some sort (bad tranny), or the bolts from tranny to motor may be loose.
any ideas on where to start looking?
« Last Edit: January 13, 2011, 04:00:17 pm by 4x4orbust »
Offline Da67goatman
  • Burban
Re: trucks squeeling like a pig...kinda
« Reply #1 on: January 13, 2011, 04:12:14 pm »
check tranny fluid, it could be too low for the pump to build adequate pressure.
<Pitcrew>
Offline 86k20
« Reply #2 on: January 13, 2011, 05:39:17 pm »
check pump belt it happend to me only in 4 hi for some reason last year couldnt figure out why
Offline 4x4orbust
« Reply #3 on: January 13, 2011, 05:43:18 pm »
I had checked the tranny fluid tues. night, and all was good.   didn't leak any that i can see, but i will check it.
i didn't think of the pump belt, i usually take it off for the summer, and i put i back on about a month ago.  might not be tight enough.  although it didn't sound like a belt squeal.
