4 Wheel Drives
cant get to go into 4 wheel drive
Topic: cant get to go into 4 wheel drive (Read 11475 times)
Buddy
January 14, 2011, 06:54:58 am »
Ok I have done a total rebuild on my truck, frame off etc. I know when i started that the 4x4 worked. I just bought this truck and tore it apart. so I know I didnt break it or damage anything. i have a 205 transfer case. all I know know is when i pull on the stick it doesnt go into 4x4. I have my hubs locked in, what did i forget to do? the wires that goes to the plug on the transfer case is all hooked up? any ideas?
Re: cant get to go into 4 wheel drive
January 14, 2011, 10:37:29 am »
Does the shifter move at all
Buddy
January 14, 2011, 08:45:47 pm »
yep shifter moves no problem
January 15, 2011, 08:48:36 am »
Does/did The 4x4 indicator light work
Buddy
January 15, 2011, 09:10:00 am »
the light did work, now i cant seem to get it to come on?
January 15, 2011, 04:15:17 pm »
Did you take the linkage off. Does the shifter move to 4x4
Buddy
January 15, 2011, 05:02:53 pm »
thats something i never tried, thanks alot! I will play with that on sunday. plan on doing some stuff to the truck than. i will post results. CHEERS
Buddy
January 17, 2011, 10:12:20 am »
Ok I got it to work, I did what you said and checked the linkage. I remebered that I removed a 3" body lift that the PO had installed. When i removed the lift the linkage was to far ahead and was allowing the truck to engae. Loosen the nut and repostioned and all is good. the only problem i have now is I still cant get the light for the 4x4 to come on?
bake74
January 17, 2011, 12:06:14 pm »
Check your wires, especially down by the transfer case to make sure they are plugged in. Glad to hear you got it to work.
74 k10, 77k10 Tom
Buddy
January 17, 2011, 12:22:17 pm »
I did check the wires at the case but I will go over everything again, you never know maybe I missed something
bake74
January 17, 2011, 12:25:27 pm »
If nothing else works check the actual spot for the 4x4 light with power to see if it is not burned out.
74 k10, 77k10 Tom
Buddy
January 17, 2011, 12:27:39 pm »
I stuck the test light i it last night and I got nothing, but I didnt do much else as far as trouble shooting yet.
jaredts
January 17, 2011, 01:02:27 pm »
You may just have to adjust the linkage again. It could be close enough to engage but not make the switch.
January 17, 2011, 05:31:44 pm »
Test the switch also make sure its getting powered then see if it works
Buddy
January 17, 2011, 05:33:59 pm »
How do I test the switch, not sure what you mean or how to do it. Do you mean the switch on the t case?
4 Wheel Drives
