Author Topic: Transmission coolers.  (Read 9156 times)
Offline oscarone
« on: February 12, 2003, 12:44:00 am »
Who knows anyhing about the correct size of aftermarket cooler to run for a tranny.  '77 k10, 383 stroker w/ a 350 tranny.  Right now I have a cooler from "Derale".  They claim it is for a 4x4 up to 20,500 gvwr.  But, the cooler just doesn't look like much.  I have it running in-line with the "stock" radiator cooler now.  I would prefer not to do this.  I blew my last tranny when the radiator blew a seam.  I kept enough coolant to cool the engine, but, not the tranny.  Thanks.
Offline 73K20
Re: Transmission coolers.
« Reply #1 on: February 12, 2003, 07:50:00 am »
Here's the one that I run: Tranny Cooler
I have had absoultly no problems with it what so ever.  I use my truck to plow snow with so you know that it has to heat the tranny up alot.  Also if you are concerned about tranny temps I would suggest installing a temperature gauge on it.
1973 K20 - 350/350/205
Offline Kevin108
« Reply #2 on: February 12, 2003, 09:42:00 pm »
I run my coolers independent of the radiator.  The rule w/ tranny coolers is run the biggest one you can fit and if you can't fit one big one, see if you can fit a couple small ones.
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | Kevin108@PavementSucks.com
Maker of 43 point turns!
Offline oscarone
tranny cooler
« Reply #3 on: February 13, 2003, 09:27:00 pm »
Thanks
Offline RSBAD454
Re: tranny cooler
« Reply #4 on: March 31, 2003, 03:50:00 pm »
www.summitracing.com im running their biggest cooler which is about 24,000 GVW i think. this is for the summit brand.....its a big cooler for about 100 bucks.
Toys are my game
http://
Offline oscarone
« Reply #5 on: April 03, 2003, 10:48:00 pm »
I installed the b&m cooler 73K20 recommended.  I have had it in for about a week.  Runs perfect, thanks.
Offline RSBAD454
« Reply #6 on: April 04, 2003, 01:39:00 pm »
sweet.........i chose the summit caue its way bigger and i have a 2500 stall for my tranny.
Toys are my game
http://
