Author Topic: one header tube glowing red?!?  (Read 16148 times)
Offline 4x4orbust
Re: one header tube glowing red?!?
« Reply #15 on: January 30, 2011, 08:22:05 pm »
just thought i'd check in.  no real updates.  had to use the truck for the last storm and didn't really notice anything different in driveability than before i saw the red tube.   still have to do the compression test.
 found a brand new MSD distributor for cheap money.   when i put that in, i'm gonna check timing, do the compression test, new plugs. maybe install a holley 600 so i can rebuild the quadrajet thats on there.  i had planned on doing all this at the end of the plow season anyway!  might as well start early.
 i'll report back with results.
« Last Edit: January 30, 2011, 08:53:48 pm by 4x4orbust »
Offline HAULIN IT
« Reply #16 on: January 30, 2011, 10:15:18 pm »
Was the vacuum hose that was open on a fitting in the intake port on the cylinder that was getting Red?
Offline 4x4orbust
« Reply #17 on: January 31, 2011, 04:07:44 pm »
it was plugged into a T on the back of the intake.   the cylinder that was glowing red is right in line with it, but wouldn't the #5 cylinder do it as well?
