Author Topic: How much lift ?  (Read 8587 times)
Offline 756man
How much lift ?
« on: January 24, 2011, 04:26:37 pm »
If I take the factory 2 leaf , negative arch leaf springs off the front axle and replace them with factory 3 leaf, positive arch 1 ton springs. How much, approximately,  will it lift the  frontend on a 79 K-20?
1985 Chevy K-20 longstepside, 350,Turbo 400
Re: How much lift ?
« Reply #1 on: January 24, 2011, 07:58:58 pm »
depending on how old and saggy the original springs are, you could get about 2-3".
Offline jdl71
Re: How much lift ?
« Reply #2 on: June 18, 2011, 07:47:37 pm »
Is this a direct bolt in? What about the back springs? Would 1 ton springs give the same ride height increase in the rear?
Offline 756man
Re: How much lift ?
« Reply #3 on: June 20, 2011, 09:11:42 pm »
Yes it is a direct bolt-on.
Offline jdl71
Re: How much lift ?
« Reply #4 on: June 21, 2011, 08:31:18 pm »
Is the truck in your avatar the one you did this to? Got any more pics?
Offline jdl71
Re: How much lift ?
« Reply #5 on: June 22, 2011, 08:02:21 pm »
Your inbox is full.
Offline 756man
Re: How much lift ?
« Reply #6 on: June 22, 2011, 11:06:17 pm »
Try it now.
