Author Topic: ideas on how to fix rust?  (Read 7676 times)
Offline 86silverado
« on: February 02, 2011, 03:51:58 pm »
Any ideas on how to fix the rust above doors on cab, like under drip rail?  can it just be welded and ground down?
Offline 86silverado
Re: ideas on how to fix rust?
« Reply #1 on: February 02, 2011, 03:52:42 pm »
you can see rust in the pic on the pillar,  that is what im talking about
« Reply #2 on: February 02, 2011, 09:00:11 pm »
     If it is surface rust you can remove the rust and prime and paint.  If it has eaten the metal, you need to remove the affected metal and replace with a donor, if you just go and paint over it, it will eventually eat through.  That area is not easy to fix, but it is doable.
Offline 86silverado
« Reply #3 on: February 02, 2011, 09:18:51 pm »
yeah it has started to pit and is bubblin in places. Will i just need to cut that out and use real small pieces of filler metal?
« Reply #4 on: February 02, 2011, 11:51:21 pm »
     If you know how to weld, the best way is to cut the strip out and replace it, or the whole door dip rail if you can find one that is not rusted.
Offline thirsty
    • Suitor's Garage
« Reply #5 on: February 03, 2011, 12:04:54 pm »
Get a small handheld blaster and see how bad it is. Might not be as bad as you think.
Offline 86silverado
« Reply #6 on: February 03, 2011, 04:43:49 pm »
would it need replaced if its pitted? I guess it would be better to do it that way and not have to worry about it in future
Offline Bitzer!
  • Smiles per gallon
« Reply #7 on: February 24, 2011, 02:39:20 pm »
Rather than blasting, use a wire wheel on a drill and skim off the paint. If it's rusty but complete I'm sure you can get some rust killer that preserves the metal. Use that then skim prime and paint.
1979 GMC CrewCab  C20 1t
Offline jaredts
« Reply #8 on: February 24, 2011, 07:11:23 pm »
Mine was similar, with no holes but some areas of ugly pitting.  I used an angle grinder with a 4" wire cup wheel and a gel type rust converter.  I alternated between the two and laid on it hard for a few hours per side.  That includes 20 minutes or more for the converter to work.  It's not the best way but its a way.  Seam sealer, prime, paint.
Offline HAULIN IT
« Reply #9 on: February 27, 2011, 07:56:14 am »
I agree with Thirsty, it most likely isn't as bad as it looks. I've seen/fixed many that looked similar to what is in your picture. Use a scraper & clean off the seam sealer, then use a sandblaster to clean it real good (cover your door opening, even with a hand-held unit...the dust goes everywhere!). On some, the top layer is just "nibbled" a bit on the edge...I've cut that 1/8" or so off with a wizz wheel & re-seamsealed. If the bottom layer has holes in it, it depends on how large of an area is effected, what tools & equipment you have. In a spot like that, a swipe of fiberglass filler in a few pinholes is really not the worse thing you could ever do. My Two Cents, Lorne
