Wheels & Tires
15" 8 bolt wheels
Topic: 15" 8 bolt wheels (Read 8669 times)
square81
15" 8 bolt wheels
February 04, 2011, 08:42:15 pm »
Ive got an 84 chevy 3/4 ton truck. Needs new tires badly. But it has the 16.5 rims on it a real pain to find tires for.I want 15" because there less hassle to find tires for and I can get a sweet deal in some BFGs for it. Can a 15" 8 bolt rim fit this truck without too much trouble or should I just suck it up and buy the other size.
zieg85
Re: 15" 8 bolt wheels
February 04, 2011, 09:44:23 pm »
We used to run 8 lug 15 inch rims on a sportsman circle track in back, don't know if they would clear the caliper in front unless the offset was right. Before disc brakes I use to see them on the 60-66 K20's...
N2TRUX
February 05, 2011, 08:22:01 am »
Pretty sure the calipers would not clear. Consider later model wheel/tire take offs.
square81
February 06, 2011, 05:57:58 pm »
Yeah good idea, those dont look to bad on the old style truck either. Thanks guys
captain carnage
February 07, 2011, 12:54:59 am »
They work, but you have to shave the calipers a bit.
bake74
February 07, 2011, 09:20:26 am »
Why not go with a set of 16" rims.
74 k10, 77k10 Tom
dcayers
March 19, 2011, 11:35:33 pm »
Quote from: captain carnage on February 07, 2011, 12:54:59 am
I have talked to quite a few of older chevy mud boggers and they told me the same as carnage said. the only reason they did it then was due to there was more of a tire selection on 15" then not the case nowadays.
1986 K5 3/4 350 tbi 700r4 6inch susp. and 3inch body 41x14.50x20
2005 Dodge Neon SRT-4 Stage 1
Wheels & Tires
15" 8 bolt wheels
