Author Topic: Question about rear differential  (Read 4774 times)
Offline burbboysgc
« on: February 04, 2011, 09:01:26 pm »
 I have a 14bolt F.F. rear. My problem is my gear oil filler bolt is stuck. I have used penetrating oil, and have still have broken 2 ratchets, and a breaker bar. Is it possible to put gear oil in the spot where the breather hose connects at the top of the housing?
1987 C20 3/4 suburban 454 tbi th 400/2wd - 1985 C10 short bed 305/350 turbo 2wd
1979 swb Custom Deluxe 2wd roller
Offline 1980c10
Re: Question about rear differential
« Reply #1 on: February 04, 2011, 09:11:09 pm »
I would keep trying, get a quality breaker bar with a warranty. maybe you can use an impact wrench.
Offline Psycho71
« Reply #2 on: February 04, 2011, 09:31:15 pm »
Maybe apply a "little" heat to the surrounding area?
Offline jthomas12287
« Reply #3 on: February 04, 2011, 10:06:42 pm »
heat it up and touch a wax candle too it. the heat lets the wax get into the threads and let them slide past each other as long as they are pipe thread
Offline burbboysgc
« Reply #4 on: February 05, 2011, 01:01:20 pm »
Thanks,for the advice. I persuaded it to come out with a couple whacks with a 3lb hammer and some Pb blaster. ;D
« Reply #5 on: February 06, 2011, 10:04:22 pm »
     They make a product called "freeze" it is in a areasol can that looks like wd40 or pb brake.  If you first use that, then heat it, most always you can get rusted things apart.  I use it at work all the time with much success.
