Author Topic: No Batt Charge At Cruise  (Read 10421 times)
Offline modular93fox
Re: No Batt Charge At Cruise
« Reply #15 on: February 14, 2011, 10:05:49 pm »
do a voltage drop on your cables. set it to dc volts, measure from one end of 1 cable to the other and you should have almost no voltage .... maybe .1 or something very very low. Example would be like battery - at terminal on battery to - battery clamp.... - battery clamp to ground contact on block... if all is good maybe the new alt is a bad one.. just becuase its new doesnt mean its good.
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
« Reply #16 on: February 15, 2011, 03:30:55 am »
thought it was a bad belt
