Author Topic: Roll pan air dam  (Read 4896 times)
Offline 81shortstep
Roll pan air dam
« on: February 08, 2011, 10:38:14 am »
Has anyone put a air dam on a pick up with a front roll pan? I have a 81 short stepside , lowered 4 front 6 rear
Re: Roll pan air dam
« Reply #1 on: February 08, 2011, 11:03:39 am »
     I don't recall seeing any with an air dam on this site, but they do make them for your truck.
Offline 81shortstep
« Reply #2 on: February 08, 2011, 12:00:14 pm »
I have been searching, do you remember where you may have seen them?
« Reply #3 on: February 08, 2011, 05:40:24 pm »
     pm sent to you, hope it helps
Offline 81shortstep
« Reply #4 on: February 09, 2011, 12:49:29 pm »
I saw those , thinking of trying to put a factory lip on roll pan. Will have to box in the bottom maybe with sheet metal and install factory one. I saw some on classic trucks ,looks like they have different widths, with and without holes for hooks. I really just want to hide front sway bar and make truck look lower on front.
Offline 81shortstep
« Reply #5 on: February 14, 2011, 05:25:48 am »
Ended up using a factory front air dam off of a 88=98 chevy pick up . Had to make a cut in center to take out some of the curve.Drilled some hole and it fit almost perfect. Will post some pics when I can. Looks awesome
