Author Topic: what dif is this?  (Read 6531 times)
Offline 1979C20
  • Kyle Taulton.
what dif is this?
« on: February 08, 2011, 05:11:04 pm »
The RPO codes from the label in the glove box says g80 differential, but This looks to me like it would be an open diff. Can you guys tell me what it is? Sorry for how big the pics are.
« Last Edit: February 10, 2011, 04:30:01 pm by 1979C20 »
Re: what dif is this?
« Reply #1 on: February 10, 2011, 04:32:57 pm »
Looks like a Gov-Loc to me...
« Reply #2 on: February 10, 2011, 04:37:23 pm »
that is a 14 bolt axle.  How many "window" holes are in it at the base of the gears?  4 = open, 3- gov loc (G80)
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: February 10, 2011, 04:49:48 pm »
I know its 14 bolt, I'm not sure on the number of holes. But I do know that when I took my truck off roading, The rear tires are both spinning. so I know it is not open carrier. I dont know when the tires are both spinning. I'm trying to figure out if its a locker or limited slip. I'm thinking its the g80 locker, as that what the options sheet said. But I figured it could have been swapped out before. How does the g80 work? I read online somewhere that it disengages at 25+mph. so, from 0-24 the tires are locked up tight?
« Reply #4 on: February 10, 2011, 05:40:31 pm »
IF it is a gov-loc it will have 3 cross shafts instead of 4.  The gov-loc works by sensing a 100rpm change between the axles and will lock both when slippage is detected.  It will stay locked until you let of the gas.  If you are driving faster than 25, it won't engage.  Under 25 with no slippage it is open.
Offline topp
« Reply #5 on: February 10, 2011, 07:45:06 pm »
What Capt. Said...
They tend to go boom eventually...
'90 Suburban TBI 350
