1988 3/4ton , 1ton differences
Topic: 1988 3/4ton , 1ton differences (Read 8880 times)
mreynolds
New Users
February 09, 2011, 05:47:24 pm »
I have a 1988 1 ton 2wd srw truck that I really like, but hate the rear gear ratio.(4.10) I drive only on the street and need higher gears. I thought I might be able to swap in a 6lug rear axle and swap the front rotors over to 6lug, but some around hear say you can't do that on a 1ton. 3/4 ton trucks they say you can. What is the big differences between a 1ton and 3/4 ton?
Re: 1988 3/4ton , 1ton differences
February 09, 2011, 06:21:01 pm »
If you have a donor you should be able to swap everything over. You can put 1 tons under a half ton so mounting isnt the big issue on the rear. For the front, the spindles out I believe are different and require 3/4T ball joints out....
Blazin
Blazin new trails!
February 09, 2011, 10:30:43 pm »
Seems like it would be allot less work to just swap in a higher geared rear, or swap the gears in yours?
Da67goatman
Site Supporters
Burban
February 10, 2011, 07:01:49 am »
Blazin: That's what I am trying to do, but finding higher gears is near impossible. No aftermarket support, so you have to look all over for a used set.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
February 10, 2011, 10:11:13 am »
What rear is it
Sartobuilt
February 10, 2011, 11:24:04 am »
Is this an R/V truck or C/K? The spring pads and shock mounts are diffrent on the R/V frame, So I dont think its a direct swap Capt.
February 10, 2011, 11:30:34 am »
A 1 Ton would have a 14 Bolt Full float
There is plenty of support for it:
http://www.ringpinion.com/PartsList.aspx?SearchMode=Make&MakeID=3&ModelID=475&Side=Rear&DriveType=RWD&DiffID=194&CatID=35
mreynolds
New Users
February 10, 2011, 03:09:38 pm »
it is a c3500. I have found a 3.42 14bolt out of a 3/4 ton, but the spring pads are wider.
zieg85
February 10, 2011, 04:06:15 pm »
Is it a crew cab?
Da67goatman
Site Supporters
Burban
February 10, 2011, 09:21:39 pm »
Yeah capt your right, I should have rephrased that. Not much Affordable aftermarket support.
<Pitcrew>
acefoxx
84 SierraClassic stepside/85 K5 Blazer
February 11, 2011, 09:54:47 am »
Check out the market for a semi floating 14 bolt. Think I found 2 lockers for mine $500 + each.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
Blue 82
February 14, 2011, 04:03:47 pm »
Just swap the 8 bolt SRW rear
I found a bunch in your state
*Edited/link inop
Try this search
Just fill in your vehicle info
www.car-part.com
I think you need the GU6 rear
Last Edit: February 14, 2011, 04:05:41 pm by Blue 82
