Author Topic: clutch pedals  (Read 6181 times)
Offline blue85
clutch pedals
« on: February 13, 2011, 08:33:17 pm »
is there any other models that the clutch pedal and brake will work in my 1985 half ton chev like what other models of gm vehicles other then full size truck? we dont have alot of older trucks here in canada the salt retires them early lol so like do little s 10 pedals or stuff like that work?
1985 c10 silverado powered up by cummins 12 valve pump tweaked hx35 turbo 518 automatic making some nice power and getting 28mpg all day long
Re: clutch pedals
« Reply #1 on: February 13, 2011, 09:20:55 pm »
     Are you talking about the pedal itself or the whole pedal, arm, and rod assy. that goes through the firewall to the frame ?
Offline Grim 82
Re: clutch pedals
« Reply #2 on: February 13, 2011, 09:26:02 pm »
Yep, more information.
Looking for replacement parts, or is this for some kind of conversion?
If you go with newer make/model parts you'll find that alot of what's available uses a hydraulic clutch.
Re: clutch pedals
« Reply #3 on: February 13, 2011, 11:15:09 pm »
The only thing that is going to bolt in is full size truck of the same vintage.
Offline blue85
Re: clutch pedals
« Reply #4 on: February 14, 2011, 06:19:11 pm »
what i am doing is converting my 85 chevy half ton from an auto transmission to a manual transmission so i need everything but wondering if there was any other model of gm that was the same or maybe the 88-98 version of truck could be used my luck up here in canada not to good on finding a manual truck
Offline KY..Rob
Re: clutch pedals
« Reply #5 on: February 14, 2011, 08:11:06 pm »
1985 Was the first year for Hydraulic clutches in our Trucks. I would start searching E-Bay and Craigslist for a 85-87 Pickup and 85-91 Blazer and Suburbans. And if you run across a Mechanical Clutch in the process, Use it till you find a Hydraulic set.
Become a site supporter, and you can post in the want adds here on the site.
