Author Topic: tank selector switch problems  (Read 7934 times)
Offline 79HIGHSIERRA
  • heartbeat of america
« on: February 13, 2011, 10:30:48 pm »
hey guys i have an issue with my tank selector switch the gauge reads a full tank but i cant hear the tanks turning on when i hit the selector switch and idk which tank the truck is on im thinking id be better to just rewire the whole switch and tanks but idk where to begin any help would be greatly appreciated thanks
Re: tank selector switch problems
« Reply #1 on: February 14, 2011, 05:28:59 pm »
What do you mean "hear the tanks turn on"?
If it is anything but an 87 with EFI, you won't hear anything unless you are under the truck, it is just a switching valve changing the source of the fuel from one side to the other.
« Reply #2 on: February 14, 2011, 07:02:19 pm »
oh well i owned an 81 scottsdale without EFI and when u switched the tanks tanks i heard a noise like the valve opening or something idk but anyways how do i fix this problem of the switch not working and everything
Offline jason d o
« Reply #3 on: February 14, 2011, 07:27:19 pm »
I know what you mean. My switching valve works all the time but when i switch from one tank ill hear a buzzing noise when it switches over but if i switch it back to the other tank i wont hear the buzzing noise, but it switches over anyway.
« Reply #4 on: February 14, 2011, 10:15:11 pm »
thats exactly what im talking about thanks jason have u ever had to fix the switch or anything like that my gauge reads full but i have no idea if its real cuz the truck was sitting for 5 years before i bought it so if u can help me thatd be awesome
Offline jason d o
« Reply #5 on: February 14, 2011, 10:37:33 pm »
Never had to fix it yet. One thing it does sometimes is when i switch over to the other tank itll go way past full. what i have to do then is switch back to the other tank and then back again to get it to register correctly. It must be a ground problem.
« Reply #6 on: February 14, 2011, 10:43:34 pm »
yea ive had that problem before on my 81 especially when i just filled the tank completely full but i just dont know where to begin with this dang switch lol and i dont wanna take it down to just one tank because the truck is on a 9 inch lift and 40s so it would be nice to have both tanks u know
« Reply #7 on: February 14, 2011, 10:53:19 pm »
     I would trace the power supply from your switch back to your valve and check both sides of the switch and valve, that way you could eliminate the switch and valve first.  Then move on to either the sending units or your printed circuit board/gauge.
« Last Edit: February 15, 2011, 09:09:17 am by bake74 »
« Reply #8 on: February 14, 2011, 10:59:58 pm »
well thank you i will try that and keep you posted on the result much appreciated  ;D
« Reply #9 on: February 16, 2011, 06:38:44 pm »
There is a tech article I posted on fixing a switch with bad connections.
