Author Topic: Need some advice...........or some help!  (Read 25461 times)
Offline edonprewitt
Re: Need some advice...........or some help!
« Reply #30 on: February 22, 2011, 08:48:24 pm »
VileZambonie,
Yep, other than the looks............. I have Fox on my toys but they are pretty pricy........any suggestions on a good quality shock for a single shock setup?
« Reply #31 on: February 22, 2011, 09:12:22 pm »
I would just run the shocks you have if they're not damaged otherwise it depends on what you are running for lift, springs, axles, engine etc
Offline edonprewitt
« Reply #32 on: February 22, 2011, 09:34:13 pm »
Just reviewed my original pics of the damage and the bracket is bent big time.......well, as well as the shocks on the left side...........Those single shocks are looking better already!  I luckily got another set of single shocks with the 2 1/2 in lift kit to replace the twisted springs from the wreck.
Thanks again
Offline thirsty
    • Suitor's Garage
« Reply #33 on: February 23, 2011, 07:33:00 pm »
I did find an 83 4x4 fleetside shortbed.....
That's the way to go.
