Author Topic: heads......problem  (Read 28221 times)
Offline 305chevy c-10
heads......problem
« on: February 15, 2011, 07:00:38 pm »
i got my EQheads in (ch350e ) .i had a edelbrock performer intake  to go with them but the heads runners are larger than the intakes ..........my question is do anyone know of a dual plane intake with large runners to fit pre 86 style intakes .(12) bolts ...........i brought the heads  with this pattern because i figured the intake would fit ...
Heartbeat of America yesterday's cheverolet
18T5C10
Offline 1980c10
Re: heads......problem
« Reply #1 on: February 16, 2011, 07:08:46 pm »
what part# is the intake?
do the bolt holes line up?
« Reply #2 on: February 17, 2011, 10:30:09 pm »
edelbbrock 2101 .........yeas they line up ...just ports not covered fully .......i did this test fit without gaskets
18T5C10
Offline 1980c10
« Reply #3 on: February 17, 2011, 10:59:01 pm »
that intake should fit those heads.
try a dry fit with the intake gaskets.
also how thick are your head gaskets?
Offline screamin86
« Reply #4 on: February 17, 2011, 11:00:45 pm »
Sounds like its time to whip out the diegrinder!
86 ta:lm7 hot cam boltons
« Reply #5 on: February 17, 2011, 11:05:08 pm »
oh so the ports on the intake can be opened up a little ..........i was in a hurry  trying to beat night fall  when i did this test fit .....never got back to it ..will re try tom
18T5C10
Offline eventhorizon66
« Reply #6 on: February 18, 2011, 03:04:02 pm »
NO!  The CH350E heads, these (right?), are a vortec port with an early style bolt pattern.  The only intake that will fit that port close enough is a raised runner intake (which are only available in single plane high rise configuration).  If you grind your 2101, you will find that you run out of material at the top of the runner before a match is met.  If you REALLY want to use that intake on those heads you're going to have to weld material on top of each intake runner, machine the mating surface flat, then port match.
Confirm what I just said, use a gasket as a template to gauge how much material you would need to remove before you whip out the grinder.
'85 C10 SWB 350 700R4 TKO600
« Reply #7 on: February 19, 2011, 12:25:56 am »
yes those are the ones......what about this  ebay item #
330354600604 these ports are close to the size of the head ports .........also intake has to clear the spider in lifter valley (roller cam block).........im guessing noone has used these heads before on here .....hope i didnt make a bad choice verse a stock vortec head
18T5C10
« Reply #8 on: February 19, 2011, 10:39:01 am »
Did you check for yourself about being able to port match the 2101?  Don't put it past me to be completely wrong.  Do this before chasing down another intake.
Also, definitely contact EQ and see what intake they intend for these heads, and report back.
Copied from their site:
EngineQuest Sales:
David Wilson (800) 426-8771 Ext. 209 djw@aaeq.net
Don Knetzger (800) 426-8771 Ext. 232 djk@aaeq.net
« Last Edit: February 19, 2011, 10:46:08 am by eventhorizon66 »
« Reply #9 on: February 19, 2011, 04:47:33 pm »
 thanks for the info .......i looked again at the 2101 it would destroy that intake trying to port match it ...too much of a diff in size .........sent eq a email about heads
18T5C10
« Reply #10 on: February 19, 2011, 05:56:21 pm »
Let us know what you find out.
Offline HAULIN IT
« Reply #11 on: February 19, 2011, 08:31:45 pm »
Where is the mis-match...on the top? I saw the Vortec combustion chamber, but didn't recall seeing anything about a Vortec intake port size. How far off & where is the problem? Is the head port larger than the intake port in every direction...as in "There would not be an obstruction of flow going from the carb toward the intake valve?" Lorne
« Reply #12 on: February 19, 2011, 10:20:11 pm »
the ports on the heads are narrow but longer than the intakes ......i may be a little off but i measured 1.140w...2.136 h on the heads .....i saw this intake on ebay SBC CHEVY SB GM Air Gap Aluminum Intake Manifold 65-95(high rise dual plane .2.09 x 1.25 port dia)....wainting on guy to let me know if he thinks it will work .......you guys check it out ebay item# 330354600604 under EBAY MOTORS
18T5C10
Offline 1980c10
« Reply #13 on: February 19, 2011, 10:48:27 pm »
from your last question;
if your intake runners are larger than you heads in any direction I would think that this would create a turbulence problem.
This makes sense as long as the 2101 has enough surface area for a tight air seal.
your heads are designed to make an unmatched intake work with the vortech design which has taller runners.
I would not order another intake without talking to some at enginequest and getting their recommendation
With heads you have, based on what they are designed to do, I would expect the 2101 to work.
« Reply #14 on: February 20, 2011, 07:48:45 am »
THE GUY ON EBAY AT kmjperformance said he think thedual plane high rise intake  should fit its has 2.09 x 1.25 port where as my heads have a 2.136 x 1.139.will wait before i order it .to hear from EQ
18T5C10
